Blown fuses
Username: Luttrell31
Post Number: 10
i have a kicker zr120 and every time i turn it up very loud it blows a fuse what could cause this i have checked my power and ground a hundred times thanks
Username: Toyo2366
Aledo, TX USA
I "had" that same amp, mine also did the same thing yours is doing. Then one day it just quit.
I never liked it because it got sooo hott!! I guess it just was hitting it thermal temp., but someone eles could prove me wrong.
Username: Dustin3
Tigard, OR U.S.
Post Number: 2459
kicker amps are very nice and shouldnt get really hott. what kind of wiring do you got (awg) and how big of a fuse?
Username: Dustin3
Tigard, OR U.S.
Post Number: 2460
make sure you have a good ground.
Post Number: 23
8ga 30 amp fuse
Username: Adddisorder
West palm, Florida
Post Number: 421
what fuse is blowing the one in the amp or the one on your power wire. im not familiure witht he specs on that amp so how many rms are you running, becasue 8 guage wire is pretty thin
Post Number: 24
one in the amp about 180 watts
Username: Caraudio
Toronto, Ontario Canada
Post Number: 517
Up ur wire to 4gauge never starve your amp for power. Knuckoncepts.
Username: Dustin3
Tigard, OR U.S.
Post Number: 2492
8 awg is fine. hes only runnin 180 watts!!
dont step up to 4 awg unless ur goin to power 600 + watts IMO
does that amp have one 30a fuse? or two?
Username: Troy81
Tavernier, Fl Us
Post Number: 631
impedance?
Username: Dustin3
Tigard, OR U.S.
Post Number: 2496
30 x 4 @ 4 ohms
RMS Power at 2 Ohms 60 W x 2
RMS Power at 4 Ohms 30 W x 2
thats the amp, not every much power. what are you runnin with this amp??
Post Number: 25
one fuse runnin one eight
Username: Dustin3
Tigard, OR U.S.
Post Number: 2514
wut 8"?
Post Number: 26
l5 solo-baric 4ohm
Username: Feaiel
Post Number: 13
Do you have any wires that r close enough to touch or just loose..especially when you turn it loud and start getting vibrations? Thermal problems SHOULDN'T cause a fuse to blow, it should just send the amp into thermal protection...and what bassman said-I'd check my ground to make sure it was secure.
Username: Dustin3
Tigard, OR U.S.
Post Number: 2532
why are you underpowering the sub soo much?
and ground is the most important
Post Number: 27
found the problem had the wrong impedance thanks
