New member Username: Ebay26Post Number: 10 Registered: Jul-06 | i have one and i was wondering how do i dub from the hard drive to a dvd and what kind of dvd do i need to do this? thanks, matt |
Gold Member Username: SamijubalPost Number: 2881 Registered: Jul-04 | DVD-R, DVD-RW. The manuals http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/dvdr.asp |
Bronze Member Username: Ebay26Post Number: 21 Registered: Jul-06 | i bought dvd+r and dvd-r. when i put them in it says ( cheack disc it may be damaged physicaly or reqires cleaning? it does not need to be cleaned and isnot damaged? any clue on what it might be? thanks, matt |
Gold Member Username: SamijubalPost Number: 2895 Registered: Jul-04 | You can't use + discs in a Toshiba. What brand and speed are the discs? |
Bronze Member Username: Ebay26Post Number: 22 Registered: Jul-06 | the dvd-r are 1-8x speed? they are r4.7gb/120min? thanks, matt |
Gold Member Username: SamijubalPost Number: 2896 Registered: Jul-04 | What brand? There are a lot of garbage discs out there. |
Bronze Member Username: Ebay26Post Number: 23 Registered: Jul-06 | panasonic dvd-r disc? thanks, matt |
Gold Member Username: SamijubalPost Number: 2897 Registered: Jul-04 | Does the disc packaging say made in Japan? If so they should be TY discs and shouldn't be the problem. Is the recorder new or used? |
Bronze Member Username: Ebay26Post Number: 32 Registered: Jul-06 | they are new disk. i call toshiba and they said that it needs new farmware and they are sending me the disk? thanks for all your help i will tell ytou how it turns out. thanks, matt |
