New member Username: PiosharkPost Number: 4 Registered: Jul-06 | I have a 2-channel amp when bridged at 4 ohms is 300x1 RMS. 2 ohms its rated at 150x2 RMS. Am I better off buying a 4 ohm SVC sub rated at 300 RMS? If I buy a 4 ohm DVC sub, can it be wired to a bridged 4 ohm channel, or does a 4 ohm DVC HAVE TO be wired to create a 2 ohm load?? Thanks. |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 2411 Registered: Oct-05 | a SVC 4 ohm woofer = 4 ohm load a 4 ohm DVC sub = 2 or 8 ohm load www.the12volt.com - then go to woofer wiring on the left A DVC 4 ohm sub HAS to be wired to a 2 ohm load wut amp do u got? wut sub? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8061 Registered: Jul-05 | http://www.the12volt.com/caraudio/woofer_configurations.asp |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 2414 Registered: Oct-05 | he must be lazy C brown |
New member Username: PiosharkPost Number: 7 Registered: Jul-06 | hey bassman thanks for replay, I have a Kenwood S726 2-channel 600W amp.. 150Wx2 rms at 2 ohms, and 300x1 rms bridged at 4 ohms I have some older rockford dvc's rated at 400rms.. was looking for a better sub to match my amp (how bad is underpowering subs anyways.. I hear mixed things).. what sub would u recommend for a 12" to go into a truck? |
New member Username: PiosharkPost Number: 8 Registered: Jul-06 | hey bassman thanks for replay, I have a Kenwood S726 2-channel 600W amp.. 150Wx2 rms at 2 ohms, and 300x1 rms bridged at 4 ohms I have some older rockford dvc's rated at 400rms.. was looking for a better sub to match my amp (how bad is underpowering subs anyways.. I hear mixed things).. what sub would u recommend for a 12" to go into a truck? One other wiring question..if I was using the amp above and hooking up one DVC sub, there would be no way to get the 300wrms to the sub, because it has to be 2 ohm stable and the amp puts out 150x2 at 2 ohms (i.e. is the 150x2 for both voice coils in one, or two seperate subs?) |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 2426 Registered: Oct-05 | kenwood amps are not very good amps. they are overrated as far as watts. if ur subs are rated @ 400 watts rms -- you want to give them 400 rms and giving them 300 (prolly around 250) wont harm anything. unless ur amp is clippin or sumthin if you had a DVC 2 ohm sub -- you could wire to a 4 ohm load = 300 rms to the sub the 150 x 2 refers to that it would do 150 watts each channel of the amp i would change ur whole set-up if i were u, it wouldnt be expensive and would sound wayyyy better and satisfy you. the RF sub and that amp, wouldnt do much at all |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 2427 Registered: Oct-05 | is that the RF P2? if you wanted to i guess you could keep the sub, but ditch the amp. (i dont like RF subs) |
