Silver Member Username: Clacla100Tallahassee, Fl US Post Number: 113 Registered: Dec-05 | my friend is looking for some component speakers priced around 100 bucks max around 150. i know its not much but for the price what would you guys recommend. |
Silver Member Username: KaerfplSpencerport, NY USA Post Number: 142 Registered: Jun-06 | Well, heres some speakers for you to look through 6 1/2: Alpine: http://www.sonicelectronix.com/item_3451.html Kicker: http://www.sonicelectronix.com/item_3571.html Pioneer: http://www.sonicelectronix.com/item_808.html Polk: http://www.sonicelectronix.com/item_6991.html |
Silver Member Username: Clacla100Tallahassee, Fl US Post Number: 115 Registered: Dec-05 | thanks for the help those alpines pretty good would you recommend any lower infinity or mbquarts |
Silver Member Username: KaerfplSpencerport, NY USA Post Number: 188 Registered: Jun-06 | If you were able to save up some more money to increase your budget to around 200-250 then ya, I could find some nice infinity's and mb quarts for you. You can always check ebay for low prices. Here, i'll look for you really quick... Here some Infinity's for under 100! Better act fast though, only 9 hours left! http://cgi.ebay.com/INFINITY-REFERENCE-6010CS-6-5-COMPONENTS-NEW_W0QQitemZ270005 185073QQihZ017QQcategoryZ32819QQrdZ1QQcmdZViewItem Couldn't find anything on mb quarts on ebay though, sorry, but you should be happy with everything that I listed for you |
Silver Member Username: KaerfplSpencerport, NY USA Post Number: 189 Registered: Jun-06 | If you need help with finding an amp for which ever ones you get, let me know and i'll help you with that also! |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 2344 Registered: Oct-05 | i'd look at some CDT's Neo's on ebay -- great speakers |
