Bronze Member Username: DualshottyPost Number: 57 Registered: Jul-06 | would two 12" mtx 4500 outperform 1 kicker comp 12" a p1 12" a pioneer entry level 60 dollar 800w sub |
Silver Member Username: KaerfplSpencerport, NY USA Post Number: 163 Registered: Jun-06 | By the Pioneer sub do you mean the TS-W301R? If so then i'd go with that. Sould be able to take on 2 4500's better than the Kicker or RF. I have one of my own and im workin on getting another one. The thing pounds and im only giving it 200 RMS. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1314 Registered: Dec-05 | Depends on the install, your box, your amp. Just because you have 2 and they're more powerful, you should win, but remember that the trick is in the box. Maybe the kicker is tuned to 60 Hz jeje lol! |
Bronze Member Username: DualshottyPost Number: 63 Registered: Jul-06 | lol i dont buy that the pioneer is best i think he has only owned that sub juliob i am gettin the two 4500s cuz they are buy one get one free now and is a kicker or mtx amp best for them |
Silver Member Username: StnorrisEldridge, IA US Post Number: 597 Registered: Apr-06 | lol^^^ two 4500s would beat 1 comp...considering 1 4500 would probably beat 1 comp. i think that 1 4500 would beat 1 p1 too... |
Silver Member Username: KaerfplSpencerport, NY USA Post Number: 174 Registered: Jun-06 | "lol i dont buy that the pioneer is best i think he has only owned that sub juliob i am gettin the two 4500s cuz they are buy one get one free now and is a kicker or mtx amp best for them" Hey, ive had and heard plenty of subs since ive got into car audio. Although, ive never heard the 4500's and I picked the Pioneer cuz I think it would have a better chance than the Kicker or RF. I never said it would win... |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1326 Registered: Dec-05 | GET 4 4500 jeje :d by the way joe, the pioneer i think you're saying is TS- 306c 400w rms sub, that thing pounds, go with mtx and buy 2+2 jjeje |
Bronze Member Username: DualshottyPost Number: 89 Registered: Jul-06 | juliob which is the best 12"sub on online stereo for under 100 and that can be powered with an amp for under 200 |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1339 Registered: Dec-05 | i'd consider CVR 12, i'll check right now. |
Gold Member Username: RovinTrinidad & T... Post Number: 8470 Registered: Jul-05 | kicker compvr & a hifonics bx1205d off ebay ... |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1340 Registered: Dec-05 | well, CVR costs 109, if you're looking for less than a 100 this would be my call http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13949 nice sub. |
Bronze Member Username: DualshottyPost Number: 90 Registered: Jul-06 | is the cvr worth the extra 9 bucks and what sub would make that thing bump for no more then 200 |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1341 Registered: Dec-05 | ooohhh.... i thought you were talking about onlinecarstereo jajjaja, rovin's post is the best call. |
Bronze Member Username: DualshottyPost Number: 92 Registered: Jul-06 | since it is dvc what ohms and rms should i look for in an amp |
Bronze Member Username: DualshottyPost Number: 94 Registered: Jul-06 | would this amp work good and if so would i want the dvc 2ohm or 4 ohm sub http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13490 |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1343 Registered: Dec-05 | if you're getting the cvr then you should get the dual 2 ohm and wire it in series if you're buying that amp |
Bronze Member Username: DualshottyPost Number: 97 Registered: Jul-06 | so the dual 2 ohm cvr and wut bout this amp http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14130 |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1347 Registered: Dec-05 | perfect, best amp for the CVR |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1348 Registered: Dec-05 | zach, check my thread, see if you can help me jeje |
Silver Member Username: DualshottyPost Number: 103 Registered: Jul-06 | would 4 gauge wiring be good then |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1351 Registered: Dec-05 | yes |
