New member Username: KoolierPost Number: 4 Registered: Jul-06 | i have two twin dish pro plus lnb, i have tried running a wire from one lnb to the "lnb in" of the other lnb, which didnt work and confirmed from other members. is there a switch or something i could use to connect 2 dish pro twin lnbs, one lnb gets 110/119 and other gets 91/82, appreciate it thanks... |
Bronze Member Username: BandizzyMarijuanaville, Stoned Easy Post Number: 84 Registered: Jun-06 | a disque switch or dp34 |
Bronze Member Username: Da_bin_chi_codePost Number: 96 Registered: Jul-06 | DP34 will not work with DishPro PLUS LNB. DP34 will work with DishPro LNB but not DishPro PLUS LNB. Dish Pro plus LNB will work with DPP44 switch though. Don't get confused with DishPro and DishPro PLUS LNBs. |
New member Username: KoolierPost Number: 5 Registered: Jul-06 | nah diseqc doesnt work tried that |
Bronze Member Username: Da_bin_chi_codePost Number: 97 Registered: Jul-06 | Readmore about DPP44: http://www.solidsignal.tv/prod_display.asp?PROD=DPP44 |
Silver Member Username: StorytellerPost Number: 105 Registered: Jul-06 | try this.. |
