Does it do any damage or effect performance of a sub to wire only one coil? I ask because I have a mono amp stable at 2Ohms and have 2 4Ohm DVC subs. I won't the amp at 2Ohms to get the most out of it. If I wire all voice coils I either get 1 or 4Ohms. If I wire just 1 coil from each sub I get 2Ohms.
well my brother only has one of the vc's hooked up on his cvr's and has had no problems, and hes had it wired like this for about 4months. but if was me i wouldn't take the chance.
Ive had one VC hooked up before on a sub. Didn't have much of a problem, but after hooking up both VC, it deff made a dramatic increase in bass. I'd just wait and get a more powerful amp, it will be worth it!
