Alright heres my problem...Right now I am running one alpine type x with a jbl bp 1200.1, I got two more alpine type x's and two more bp 1200.1's as well(not hooked up yet). The amps do not have rca out's on them so what would be the best way to run rca's to all three amps?
No the amp does not have low level output jacks, it has front/rear high level. The only conclusion i could come up with was the rca splitters, but would I split the rca's from the back of the deck, or just split them in the trunk off of the rca's? And if I do this would all those splitters interfer with the sq?
Yea, whys he need 4? uhm.... Four splits, 2 left, 2 rights, Well Looks like you only need two set.
Dissclaimer. Information published by me is for entertainment purposes only. Please use common sense when determining if information obtained is valid. Do not responde to errors posted.
