I have a pansat 2700a and when it went out a month ago i havent had time to update to the new 272 bin file until now.After flashing the reciever with the new bin, i went in and set it to defualt key and went back to wait for the tv to appear.It tried to autoroll and after about five minutes it came back and said bad or scarmbled channel.I went into the N2 to check to see if the codes autorolled and they were correct.(00 and 01).Im lost on the problem because the keys are rolled right but yet it still says scrambled.I tried truning off autoroll and eneter the keys myself but that didnt work and i also reflashed with factory bina and then back with the new bin with no luck.Can anyone help mw out with this!!!I would appreciate it!!!!
You're not up-to-date mate. Dish recently did an ECM and therefore almost all the channels on DN are black. You're better off with Nimiq 1 because most of the channels on Nimiq 1 are still open.
read you dumb fcuking idiots...nimiq is canadian sat, it's over to the left of DN...and yes lots of channels still working, if you had a fcuking brain you would know that...ROTF
