Bronze Member Username: Fortec16Post Number: 51 Registered: May-06 | Bell Express Vu Black box should work? If I have the Yellow card? Where Do I programm? Where do I get the file? how is works? |
Bronze Member Username: Moe948Post Number: 77 Registered: Jun-06 | You need the rom 102 card and the latest blocker file from Penga. |
Bronze Member Username: Fortec16Post Number: 52 Registered: May-06 | Can you give me more details please |
Bronze Member Username: Moe948Post Number: 78 Registered: Jun-06 | Search 'rom 102' on ebay. You'll know what it is. Even if you have a yellow card, you need to know what kind of card it is. It can be rom 101 as well. And here is the latest blocker file: http://dsstester..com/download.php?file=878&go=1 (remove the extra dot before com) |
New member Username: BrucesterPost Number: 1 Registered: Jul-06 | hi i'm new at this i just bought a captive works model cw-600s premium get lot of channels but no ppv no venus channels how can i get them to work please and thank you |
Bronze Member Username: Moe948Post Number: 80 Registered: Jun-06 | Bruce.. PPV and Venus are black for now. You have to wait till a new bin comes out. And if you wanna know when the bin will come out.. well no one knows |
Bronze Member Username: Fortec16Post Number: 53 Registered: May-06 | where u I find the yellow card? |
New member Username: BrucesterPost Number: 2 Registered: Jul-06 | thanks moe try tomorrow |
Bronze Member Username: Fortec16Post Number: 54 Registered: May-06 | i have my old black box need yellow card how do i program? |
Bronze Member Username: Fortec16Post Number: 55 Registered: May-06 | idea pls |
Bronze Member Username: StorytellerPost Number: 90 Registered: Jul-06 | Hacking plastic will take you a couple of months to learn!...its nothing like FTA..FTA is simple..plastic is 100x more difficult and requires 100x more time reading and testing..go to dsstester.c*om and start reading the Dishnet area if you really want to learn plastic.. |
Bronze Member Username: BandizzyMarijuanaville, Stoned Easy Post Number: 80 Registered: Jun-06 | not to be rude but for me i switched to plastic and after i got all my sh?t i had 6 boxes up and running in a week and no proir knowladge of rom 102's. it just depends on the time infested i researched for 2 weeks before i got my first box. |
Bronze Member Username: Fortec16Post Number: 58 Registered: May-06 | Can I use the disque switch from FTA? I have 91w,82.5W,121w and 127w. so I have 4 Dish to work Bell expressvu Black Box? Where do I find the yellow card cheeper? |
Bronze Member Username: Fortec16Post Number: 59 Registered: May-06 | any comments? |
Silver Member Username: FruitcakesPost Number: 108 Registered: Jan-06 | wow...what a bunch of dumb fcuking retards on here...ever heard of "Read, read, read, until your eye's bleed"...If you read for about a week, you would know everything about FTA and what's going on...lazy fcuking idiots...ROTF |
Bronze Member Username: Fortec16Post Number: 60 Registered: May-06 | Hay Fruitcakes! Who is tolking about FTA? We are talking about ROM 102. I guess U shold read b4 what u write. Stop using the bad words on the foum. |
Silver Member Username: FruitcakesPost Number: 110 Registered: Jan-06 | hey gus...lick my ballsack buddy, if I wanted to hear from an azzhole, I would tout...ROTF |
Bronze Member Username: BandizzyMarijuanaville, Stoned Easy Post Number: 81 Registered: Jun-06 | dont know about that switch with bev or dish recievers. i use dp34 |
New member Username: Marco_gPost Number: 4 Registered: Jul-06 | I se a bunch of retards, in a bad mood, cause dn is down,, relax,, i no time there's gonna be a new,, bin and all of you guys can spank it as much as you like:-) LMAO |
Bronze Member Username: NeurosisPost Number: 44 Registered: May-06 | marco why wait until DN is back up? ;) |
Bronze Member Username: Ong_tuPost Number: 42 Registered: Jun-06 | Go to http://www.ha*hhu.com/ you won't have to put up with fruitcakes!! Replace * with s |
