Me thinks i buggered up something
Username: Fumate
I've a Pansat2500A clone with two dishes, each single LNB, one was pointed at Echo110 and the other at Echo119. Both dishes are connected to DiSEqc 2.0. I checked the cables, Echo119 was connected to LNB4 AND Echo110 was connected to LNB3. I moved one of my dishes and attempted to point it toward Nimiq1. I went into Antenna Setup, Nimiq1 - changed 22kHZ on and DiSEqC to #4 as that was the dish I moved. After attempting a blind scan and not reading any transponders I realized the dish was pointed at the bottom of the balcony of the apartment above me. I moved the dish back to its original position and have tried blind scan for Echo119, the original satellite it was pointed at and now get no transponders. Any advise/instruction would be much appreciated.
Username: Ong_tu
Post Number: 43
Go to http://www.ha*hhu.com/ you won't have to put up with fruitcakes!! Replace * with s
