Help with 119
Username: Popogrow
I got from Ebay a Dish Network Dish 500 Dish W/Legacy Twin LNB FTA
about a week ago and I cant seem to get 119 all I get is 110 what am I doing wrong I am using a 4x1 DiSEqC 2.0 Switch one to 110 and 4 to 119 and on a cool sat receiver
Username: Moe948
Post Number: 62
No point in trying for 110 or 119. Almost all the channels are dead on those two. Try looking for 91 and 82 which still have a lot of channels open.
Username: Popogrow
thank you
Username: Moe948
Post Number: 65
Well, they are dead.. but if you have the a receiver with a card slot and a rom 102 card then 110 and 119 are still open.
Username: Woofy
Ontario Canada
Post Number: 258
popo grow..your setup is wrong..your legacy twin has a built in switch..so you do not need to use the disque switch...just run one rg6 cable from the lnb straight to your cool*sat and use these settings.
119
lnb power - on
lnb type - legacy twin LNB1
lnb freq - 11.250
22 khz - off
disque switch - 1.0
committed - 1
legacy sw - off
110
lnb power - on
lnb freq -11.250
22 khz - off
disque switch - 1.0
committed - 2
legacy sw - off
lnb from 119 to disque swtich port 1
lnb from 110 to disque switch port 2
Username: Woofy
Ontario Canada
Post Number: 259
oh yea..110 should be legacy twin lnb2
Username: Popogrow
Post Number: 7
Will do thank you fot the info.
Username: Popogrow
Post Number: 9
Will do, Thank You for the info.
