Are boss amps any good?
Username: Naledge503
Portland, Oregon U.S.
I was just wondering if there is anybody that knows if boss amps are any good.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 121
No...not really
Username: Illuminator
Post Number: 3341
No, but PPI and Zapco amps are good.
Post Number: 7
on a boss amp that says 1700 rms @ 2 ohms and 3500 max, what do you think the true power would be?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1196
800-1000 at 2 ohms, jexx nice joke. If you're on budget look hifonics
Username: Troy81
Tavernier, Fl Us
Post Number: 516
way overrated but a watt is a watt, the one i worked with had good cooling fans so it didnt get hot
Username: Dustin3
Tigard, Or U.S.
Post Number: 2158
wut r u lookin to power?
Post Number: 8
2 cvx 12D2, i'm on a $250 budget and i know that aint gonna get it done so i'm just lookin for a budget amp. not for SQ.
Post Number: 3346
quote:
a watt is a watt,
True...but that's only until the amplifier starts clipping, with cheap amps, it happens faster and is much more noticeable because they have subpar power supplies.
Username: Dustin3
Tigard, Or U.S.
Post Number: 2163
could you look at a kicker zx1500??? its 2 ohm stable so you can wire down to 2 ohms and get 750 to each sub...
Username: Troy81
Tavernier, Fl Us
Post Number: 518
i dont believe in that a watt is a watt at all, but every one on here seems to for some reason
Username: Rovin
Trinidad & T...
Post Number: 8420
only the ripper d3 & IQ series from boss r really worth something , both put out close 2 their 1000wrms rating , d3 does it @ 20hms while IQ is @ 1 ohm.
Really i wont rec some1 2 buy boss when there r better stuff out there even on a budget - look @ Hifonics & Directed amps > both r way better .......
Post Number: 9
I was looking at some directed amps too, and some power acoustik, and MA audio. I'm thinking about going with a phoenix gold, R15.0:1 and under powering them.
Username: Dustin3
Tigard, Or U.S.
Post Number: 2174
Dont underpower CVX's. they are good subs and you should give them the RMS rating. at least go for this, its like 280 and will put out 1500 watts @ 1 ohm.
http://cgi.ebay.com/HIFONICS-BXi1606D-Class-D-Mono-Amplifier-Amp-BXi-1606D_W0QQi temZ300004072243QQihZ020QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Dustin3
Tigard, Or U.S.
Post Number: 2175
or if you want somthin pretty cheap, you could get 2 audiobahn a8002t's which are like 120 each. so around 240. this will give each sub 800 watts
Post Number: 10
i cant run 2 cvx 12D2 at 1 ohm it has to be 2 ohms, if i'm going to go with audiobahn, do you think i should go with the A16000V instead. it is 1600 rms @ 2 ohms and i can get it for about $230
Username: Dustin3
Tigard, Or U.S.
Post Number: 2177
ohh yea. i forgot u had the 2 ohm version.
yes, you could get the a16000v, but the only reason why i said the a8002t's is becausae i kno for a fact that it puts out the rated power... the higher up audiobahn amps i am not sure of... but yes, the a16000v would be great. i would get it
Post Number: 11
Yeah, i had a a8002t running 2 10" audiobahn aw1005n and even though it was way underpowered, it hit almost as good as my older system which was 2 jl 12w3 with a older style rockford fosgate 250a2. i was really surprised.
Username: Dustin3
Tigard, Or U.S.
Post Number: 2178
ya. they are nice amps
Username: Juliob
Post Number: 1217
IDK about the 1600V i don't recommend it, get 2 a8000t's. The16000v is kinda questionable and audiobum high end stuff tends to blow.
Username: Dustin3
Tigard, Or U.S.
Post Number: 2218
^^^ and heats up pretty fast
