New member Username: TangregGeorgetown, TX United States Post Number: 1 Registered: Jul-06 | I am very confused right now, and I need some help. I have a Sony 30" HD Ready TV, with Dish Network HD package. The HD channels I suscribe to are great, but I cannot get Network HD. The people at Dish say I should be able to, but do they mean "over-the-air"? If that is the case, I cannot receive them because I only have an HD ready TC, not one with a built in tuner, correct? Any clarification on this topic would be great. TIA |
New member Username: DrdaveNewport Beach, CA Post Number: 3 Registered: Jul-06 | The DISH 811 box if you have that, has an antenna input, where you can go buy a UHF antenna and connect. The 811 will merge all of the signals and you will get them. You should be able to get some Austin stations from where you live with a simple antenna from Radio Shack. http://www.antennaweb.org/aw/Address.aspx that web site will tell you your reception and type of antenna.. I also think that some are available in the HD station area direct from the cable. |
