When wiring an amp in the house.......
Username: Blainew
Post Number: 1353
how do you ground it???
Username: Rovin
Trinidad & T...
Post Number: 8424
ground is - , hook it 2 ur - batt or power supply terminal.....
Username: Illuminator
Post Number: 3362
How exactly are you powering it? Grounding it shouldn't be a problem if you use a good power supply. http://cgi.ebay.com/Astron-RS-35A-13-8-VDC-35-AMP-Regulated-DC-Power-Supply_W0QQ itemZ290004583925QQihZ019QQcategoryZ48708QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
(+) and (-) binding posts in the back for the amp.
Username: Blainew
Post Number: 1355
wellll.... i have a battery charger, what if i just put a batt charger, onto a car battery in my room.... will that work??
Post Number: 3365
Though that is a good concept...Don't use a car battery in your room. That's very dangerous-especially because of the toxic hazards.
If anything, just use the battery charger as your power supply.
Username: Blainew
Post Number: 1356
yea i was thinking of that too....but how do i ground the stuff
Post Number: 3370
The negative cable is the ground. When you ground a cable in a car, you're essentially just connecting it to the negative terminal of the battery, since the negative terminal of the battery has a wire going straight to the car's chassis (sorry if you already knew this, I'm just clarifying things).
Username: Blainew
Post Number: 1357
but how ... if i have an amp and a batt charger in my room,,,, how do i ground it..
Post Number: 3372
Hook up the negative terminal of the amp to the negative battery cable.
Username: Blainew
Post Number: 1358
so... i have the batt charger plugged into the wall, the poitive of the batt charger to the positive of the amp, and the negative of the batt charger to the negative of the amp???
Post Number: 3375
Yep, and you also need to hook up the remote wire of the amp to the positive battery charger cable.
Username: Blainew
Post Number: 1359
thanks alot!
