07/07/06--> [From Viewsat] We are working around the clock to get everyone up and running soon, We hope to finish by end of next week, FTA will Live on for a longtime,we are every close... We have find Great info, that we will live on for a long time. This one is not easy, but we will have problem solution soon. Please be patient. We are making file do update just like there. this one is not going to be temp,,,, fix but full fix,,,
We are being help on this one from some europe guys on this one
I'll just be waiting and watching caus everyone giving predictions, even though im an optimist, i still aint taking every one who says that Jesus is coming back by weekend
I'll just be waiting and watching caus everyone giving predictions, even though im an optimist, i still aint taking to every one who says that Jesus (a perm. fix) is coming back by stated times.....but anyway guud luck guys
Mussawel..., If you are calling this C & P update BS, why the hell did you post the same C & P update on the "No Fix Coming" Thread 6 minutes later? lol
I consulted the psychic hotline and have been informed that there is a good likelyhood that the new bin(s) will be out this year. However, Dion Warwicks friends have also stated that DN will send a new ECM w/in 2 weeks of the new bin.
Blocker stops DN from changing data on the card, FTAs can't be changed this way, have to plug them into a computer, so no blocker needed, a blocker does not get you any channels.
This latest change has nothing to do with speed or memory size
This is the simplest way I can explain why there is no fix yet:
In a DN card there are 2 MAPs (math processors), that I know of..........there are probably more.
These MAPs change numbers, or modify number strings.
They use unreversable math, so even though you know the number going in and the number coming out, you cannot detemine what math was used to make that change, so you can't duplicate it just by knowing the answer.
The MAPs are readable, but it takes awhile to get each step.
The MAPs themselves can be modified by outside settings, this makes these MAPs multi-level if you will.
So it's not just a matter of getting one single read of a MAP and you're done.
Now to have an FTA fix you need both MAPs and all possible combinations of those - this will take awhile.
For cards you need none of this, the MAPs are built-in, so you don't need to know squat about what's going on inside the card............this is why card sharing works.
DN has never tried to stop FTAs from getting their channels until now........it does not surprise me that a fix will take some time.
Until now, all they did was fake packets and changed the auto-roll signature; so basically, they did nothing. The rev108 update shut down the FTAs for a few days using a few MAPs calls, while the rev109 update still has them shutdown using many MAP calls........for how long, who knows?????.......But they will be back up, ..........at least until rev10A.
I am sure the coders appreciate all the suggestions offered by non-coders, but they know where the problem lies, it's just a matter of getting the info.
not really, actually this makes a lot of sense, because the key is to know the method you are using to get your output, the output itself is useless unless you know exactly how you got it. Now we can't just say black box, we need to know how it is functioning. I think we're after something here ...
So people are not getting FTA ?? i got a co*lsat 5k and superdish and getting a bunch of chennels from B*v but no ppv or P*rn. Never been interupted so it amazes me. is it something i should be ready for??...
hI raymond there is a a kinnd oof maths they use linear algebra...a matrix as you know this kind of operation take a lot of time y have also some probabilty its not easy but there is many gys who do this kind of work
