Loudest db, count with a single kicker 1200 amp.
Username: 420pimp2
Post Number: 760
If you were put on a show and you had to use a kicker 1200 amp, what 2, 12 inch subs what would you choose and how would you set them up to get the highest db record in that catogory. Just off of the top of your head what would you think about using.
Remember Pure spl.
Los Angeles, CA USA
Post Number: 4236
2 kicker cvrs in a 8 cuft net common chamber with 125sq inches port tuned to 46hz.
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 441
would L7's or L5's almost work better since hes only concerned with spl?
Los Angeles, CA USA
Post Number: 4241
well its 1200wrms amp. you would be underpowering the L7s. the L5s would work with that amp though. but i've never heard the L5s and have owned the cvrs so i am just posting from my experience with the subs.
Username: Genocyde21
Post Number: 48
Woudn't the size off the box compensate for the missing watts? If i look at a brahma, they say u can give it 1000 wrms, but the bigger the box, the less wrms u have to send it...
Username: Zacdavis
Beloit, Wi
Post Number: 435
2 Kicker L7 Dual 2's wired parallel to a 1/2 ohm load, ported enclosure, 14x14x28 with 2 4" aeroports 12" long. Put this set up in a Honda CRX, have the box laying on its side(subs facing drivers side of car) ports firing back and keep an 18" gap between the back of the car and the box.
Username: Zacdavis
Beloit, Wi
Post Number: 436
Btw, Chad, the Kx1200.1 puts out a ton more than 1200 watts!, it's underrated at 1 ohm, and at 1/2 wow, it really comes alive. And if you know what your doing you can get some serious power out of them at 1/4 ohm.
Los Angeles, CA USA
Post Number: 4242
damn zac. 1/4ohm on that amp? thats tight. you really know what you are doing there.
Username: Dustin3
Tigard, Or U.S.
Post Number: 2083
lol. yea, thats impressive... .25 ohm
Username: 420pimp2
Post Number: 768
wouldn't that fry somthing?
Username: 420pimp2
Post Number: 771
didn't bump fu.ckin p.o.s ecoustics server
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1163
You're gonna get loud, remember to put some 3 6 mafia to get some high bass notes jjeje
Username: Zacdavis
Beloit, Wi
Post Number: 437
If this system were in this car (crx) the note you would want to play would be between 60hz and 63hz. you couldn't play music on these amps at 1/4 ohm, only burps at the resonant frequency of the vehicle, with this particular set up in this car there is a bit of impedence rise that will allow this amp to have a 1/4 ohm reactive load ran to it. A fixed resistive load would send this thing into protect quicker n sh!t lol.
Anywho, thats my set up idea for ya man, at least with the Kx1200.1 you've got.
Los Angeles, CA USA
Post Number: 4251
approximately how much watts would you be seeing if you were to burp with the amp at 1/4 ohm zac?
Username: Hdubb
Farmington, Nm Usa
Post Number: 2069
yeah zac def. knows what hes talking about. im not sure but he might stll hold a record. you still hold that zac? id say youd proly see about 3000 watts at 1/4 ohm but like he said thats only for burpd, and not for very long
Username: Skies
Courtenay, British Colu... Canada
Post Number: 200
zac didnt you have another account with like 1000+ posts ?
BTW, props on the 1/4 ohm :P
Username: Th3di3s3l28
Post Number: 22
i would use the new cvx
maybe because thats what im running :p
Username: Stnorris
Eldridge, IA US
Post Number: 526
why u copying my name. theres only room for one of us.
Username: Sploosh56
Ohio
Post Number: 1408
hey zac, whatever went down with everything when your shop got robbed?
Username: Drsmith
Montana USA
Post Number: 39
steven what do you think of your cvx i have 2 12's but am still waiting to install them
Username: 420pimp2
Post Number: 780
bump
Post Number: 26
Well, I love them to death. I used to have 2 12" CVR's, and I sold them to get the CVX's. Basically, it's what they tell you, it's a solobarics loudness, with the quality of a round sub. I love them. They get loud as hell. But they sound really good. What amp are you using? I've got a ZX1000.1 putting out almost 1200 watts to them.
Username: Drsmith
Montana USA
Post Number: 40
i have a RF t1000 birthsheet says 1657 RMS at 1 ohm
Post Number: 28
Not bad. Yeah my birthsheet says 1192 so its around 600 going to each sub. You'll love em. Trust me
