Make up ur mind! sealed or ported?
Username: Pelona
Perris, California USA
Post Number: 1654
so wut goes lower sealed or ported? or does it depend on the subwoofer?
Username: Halter
Paulding, Ohio
Post Number: 116
depends on it all..ported would be the way to go for spl... and port it about 32hz and u will be hittin some good shaking low bass!!
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1251
i agree
Username: Dustin3
Tigard, Or U.S.
Post Number: 2248
ported
Username: Sploosh56
Ohio
Post Number: 1410
if the sub can be used for either sealed or ported I'll go ported
Username: Pelona
Post Number: 1655
really? well this is wut i think that if u get a large sealed box and a ported one tuned at 27hz and play some rap
they will both reach the same lowness just that the ported one will have a little more spl around 27hz
because lets say the songs bass only reaches down to only 25hz so below that it doesnt really matter.
but if u have a song that reaches all the way down to 15hz(i doubt there is one) the sealed will hit lower because sealed can reach lower all the way down to the subs Fs(if its as low as 15hz) and the ported will have a steep dropoff at 27hz so it wont hit as low
do u know wut i mean? am i right?
Username: Pelona
Post Number: 1658
g
