can i use a sub kicker CVR15 2-ohm with an amp Crossfire CFA602 Amplifier 300w x 2. 600w @ 4 ohms bridged? if yes, what is the correct way to wire them?
thanks julio, but i want to be sure in something: the amp is two channel and the sub is dual, do i have to connect using bridge? or 1 channel per voice coil? regards
