Username: Jamo Post Number: 28 Registered: Jun-06
Tuesday, July 04, 2006 - 23:20 GMT will this work on those 3 audiobahns PHOENIX GOLD OCTANE R15.0:1 1500W MONO AMPLIFIER
Username: Jamo Post Number: 29 Registered: Jun-06
Tuesday, July 04, 2006 - 23:22 GMT or would this be better NEW VOLFENHAG MONO 1800-W AMP CLASS-D ZX-MONOBLOCK neon
Username: Tjmutlow Post Number: 2536 Registered: Sep-05
Tuesday, July 04, 2006 - 23:23 GMT yes, it is 2 ohm stable....
Username: Tjmutlow Post Number: 2537 Registered: Sep-05
Tuesday, July 04, 2006 - 23:23 GMT the pg is better
Username: Jamo Post Number: 30 Registered: Jun-06
Tuesday, July 04, 2006 - 23:26 GMT KENWOOD EXCELON KAC-X812D 1600 WATT MONO AMPLIFIER 2006 will any out of these 3 work??????????
Username: Ctmike Ct.
Post Number: 946 Registered: Feb-06
Tuesday, July 04, 2006 - 23:26 GMT mike, stop making new threads, this is the 3rd thread for the same question in half an hour.
Username: Tjmutlow Post Number: 2542 Registered: Sep-05
Tuesday, July 04, 2006 - 23:29 GMT again another garbage amp.....
Username: Juliob Santo DomingoDominican Re...
Post Number: 1101 Registered: Dec-05
Tuesday, July 04, 2006 - 23:36 GMT it doesn't matter too much if they're two ohm stable, the difference is the amount of power cuz the impedance is 2.67, YOU NEED A 1700W RMS AT 2 OHM AMP!
Username: Tjmutlow Post Number: 2544 Registered: Sep-05
Tuesday, July 04, 2006 - 23:39 GMT yes it does, you do not want a 1ohm stable amp, the power needs to0 be closet to max at 2 ohms..... not 1 ohm.
