Username: Jamo Post Number: 20 Registered: Jun-06
Tuesday, July 04, 2006 - 17:09 GMT will the Kenwood KAC-9102D Mono Car Amplifier Class D 1700 Watts work for 3 12" audiobahn AW1251SE that are 400 watts rms each are dual 4 Ohm and 2 or 8 Ohm operation
Username: Dustin3 Tigard,
Or
U.S.
Post Number: 2002 Registered: Oct-05
Tuesday, July 04, 2006 - 17:32 GMT that amp does 850 watts x 1 at 2 ohms bridged... you would be lucky to get 150-200 watts to each sub. so no, it wouldnt work
Username: Tdawg30 Ohio
Post Number: 46 Registered: Jun-06
Tuesday, July 04, 2006 - 17:39 GMT yeah plus the features on it arent so great. the controls are hard to get to and its just a pain in the @ss. thats why i sold mine.
Username: Juliob Santo DomingoDominican Re...
Post Number: 1072 Registered: Dec-05
Tuesday, July 04, 2006 - 18:35 GMT you should try getting an amp that does 1700w at 2 ohms, orion 2500d or check some kicker models
Username: Tjmutlow Post Number: 2529 Registered: Sep-05
Tuesday, July 04, 2006 - 21:04 GMT need an amp that does max at 2 ohms, like if need cheap the audionbahn a16000v like @250 delivered...
