Username: Randomxunknown Post Number: 9 Registered: Jun-06
Monday, July 03, 2006 - 23:22 GMT i have 4 5.25 all the way around in my car, and the bass from them sounds horible. is there anyway to correct this without/ last ditch effort of buying new? and if i do what would be the best bang for the buck, im not looking for bass responce seeing as i have 2 type R 12's in the trunk.
Username: Rick_ross Post Number: 221 Registered: May-06
Monday, July 03, 2006 - 23:24 GMT if u have two type r's then u dont need the bass from the regular speakers just turn it all the way down or use bass blockers
Username: Tjmutlow Post Number: 2526 Registered: Sep-05
Monday, July 03, 2006 - 23:38 GMT put an amp on them and use at high pass and adjust radio settings accordingly.
Username: Dsmith07 Post Number: 62 Registered: Jun-06
Tuesday, July 04, 2006 - 00:57 GMT i 2nd the idea about bass blockers!
Username: Randomxunknown Post Number: 11 Registered: Jun-06
Tuesday, July 04, 2006 - 20:49 GMT how much/ could i use a resitor to block out the bass? and where could i get some for cheap?
Username: Fandim Reno,
Nevada
United State...
Post Number: 1266 Registered: Jun-05
Wednesday, July 05, 2006 - 15:27 GMT You could use a home made crossover as a bass blocker, basically, yes. However, bass blockers are like under $10.
