OT:wiring question
Username: Gangstafert
Jacksonville, Florida USA
Post Number: 225
OK im a noob at ths but i want to do it right i am going to running 2 arsenal 12's off of a autotek MM1400.1. If im not mistakin i run a 0gauge wire from my battery to a distro then two 4 gauge wires off of the distro.but where do the two 4 gauge wires go?and correct me if im wrong. thanx. i should also need three fuses???
Username: Rovin
Trinidad & T...
Post Number: 8320
that amp has only 1 power terminal right ?
or if u meant y a disro block with 0 > 2) 4g wires
use 1 4g on ur mono amp & 1 4g on ur 2/4 chan amp if u have 1 ....
Post Number: 226
i dont have another amp yet and im not and it ould be awhile before i do so what do i do just for the mono?
Post Number: 227
anyone?
Username: B101
Queen City, NC USA
Post Number: 3464
u need to run 0ga or 2ga to the back of the car from the front batt!
u need 2 distribution blocks (neg + pos)
u need 2 short runs of 4ga wire... (1) for positive to the amp (2) for the negative to the amp
THATS ALL IT IS TO DO!
Post Number: 229
So the amp has two power terminals.Im sorry thats where i was getting confused. I need two distro blocks?
