Rogers digital cable
Username: Nels2k
Post Number: 36
is there anything u can do to a rogers digital cable box. i've never heard of hacking cable but there must be something. just wondering wat can be done.
Username: Watzupwitu
Post Number: 33
Does anyone know how to hack the hell out of the new digital cable boxes?. Have we been shut out of both satellite and cable for good??. All I get is public access tv but when you watch it drunk and high, it turns into p@rn. That's what I was told.
Username: Nickb
New York, New York USA
Post Number: 74
YEAH!!!!
I want to know learn more about that tooo!!
I heard way back that there's some filter you get to stop information from things you ordered from going back to company...but I'm really not sure about it.
Is there anything that can be done to digital cable???
Thanksssss
Username: Nickb
Post Number: 75
LOL :D HAHAHAHAHA!!! :-)
PBS does have the occassional adult programming ;-) LOL
Saturday night British comedies are the only good thing on there.
Sometimes Nova is good...but rest is boring.
I want to know how to 'test' digital cable myself...any oneee?
Username: Aae2k2
Yes! R@dioSh@ck has a filter that costs about $4.00 you can purchase you simply install it backwards...however this will only work on ppv that you purchase...Oh yeah, you need to make d@mn sure you do a hard reboot on your cable box before the cable co. ever gets their hands back on it because they will see and then subsequently charge you for all that you stole...I mean tested, hehehe
Post Number: 34
Nick, I've tried that filter before, doesn't work. It was nothing but a scam.
Username: Aae2k2
Tony, So you`re telling me that a 54-1000 mhz filter installed reverse polarity in-line doesnt work? Nick...just try it, dont let other peoples negativity and defeatist attitude stop you...besides, it`s $4.00!!! If I were gonna mess with you I would try talking you into something useless that would cost a helluva lot more than $4.00. Good Luck
Username: Nickb
Post Number: 76
OHH..sucks!!
I thought that would work...:-(
Username: The_wank_artist
Post Number: 1222
Just put an old VCR in front of it, which stops the two way of the box and the sending of PPV info back to homebase.
Then as Dave says hard boot the box to erase the memory.
Username: Aae2k2
Tyler...Ive never heard of the old VCR trick, I`ll be tryin that out...Thanks!
Post Number: 1225
Yeah, VCR's don't work in a two-way capacity so if you run a cable from the wall to VCR, then to box, then to TV, they usually stop the return signal.
At least they used to.
Don't keep it too long like that or you'll be flagged as having a faulty set up and you may get a visit from you know who...
Post Number: 35
Dave, I wasn't talking about the radio shack filter, I've never tried that. I'm talking about the ones online like this;
cableboxfilters.c0m
I bought one from online and ordered ppv and the sent me the bill.
Username: Justauser
So if the filter is installed and preventing 2 way communication, how does ordering via the remote work?
Username: Hardrockstriker
Post Number: 228
Tony, did you clear your receiver's memory, like the website says?
Username: Nickb
Post Number: 77
Thanks Dave...I will try the filter...and seeee :-)
And thanks Tyler..that VCR trick is geniuss...I will try it out.
Thanks guys!
Post Number: 37
Yes, I did that.
Post Number: 1229
You still order via the remote.
I think the box stores purchases in memory until home base sends a blast telling all the boxes to return the purchase info. The box gets the message, sends the info but the VCR/Filter stops the message at that point as the two way signal is prevented.
Under normal circumstances, the home base would send an additional message to those boxes that have answered, clearing the boxes purchase memory. But since the message was stopped mid way, the box does not get the erase message and the purchases just sit there. You have to figure that the box has a limited capacity of how many (or how much $$) it can hold at one time before preventing more ordering.
Username: Impala1977
Post Number: 19
But how do you do a hard reboot on a cable box?
Post Number: 1230
= hard boot
Username: Lucia
Post Number: 199
we got televitis!!!!!!!!!!!!!!!!!!!!!!!!!!
Username: Troops
Toronto, Ontario Canada
Televitis????????? sounds like an std......lol.
Username: Justauser
Well, I guess my point was, if the box can not communicate with "home base" how can you order a pay-per-view ?? I actually did have a dvd recorder between the wall and the DCT6208 and it did prevent my "Movies On Demand" from working. I could not select any movies at all from the menu. I did not try any ppv but later found out that I could not have anyway, since on my account, my credit limit was inadvertantly set to Zero.
Username: Kcnda
Thanks Dave I will try the filter and see if it works.
And thanks Tyler that VCR trick Sounds Like it's good I will try it out too.
Thanks guys!
