Bronze Member Username: Tiggerboi87Pensacola, FL United States Post Number: 40 Registered: Jun-06 | Can the ohm of a subwoofer be changed to another ohm for example a 4 ohm sub to a 2 ohm. |
Silver Member Username: DannyboyyPeterborough, NH USA Post Number: 254 Registered: Jun-06 | yes if it is a dual voice coil subwoofer or you have 2 of the same woofers. |
Bronze Member Username: Tiggerboi87Pensacola, FL United States Post Number: 41 Registered: Jun-06 | yea its one alpine type-r 12. I got the 4-ohm one not knowing that the 2 ohm works better with most amps and especially with the one that i have. |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1943 Registered: Oct-05 | you cant chage a DVC 4 ohm sub to a 2 ohm sub. because the 4 ohm sub can be wired to a 2 or 8 ohm load and the DVC 2 ohm sub can be wired to a 1 or 4 ohm load. you cant just chage the impedences. only how they are wired. if you wanted diff ohm sub, you need to exchage it. and the 12" type r will work with some amp but not alot of good quality amps. the first one that comes to mind would be a pheonix gold xenon 600.1 which can accept a 1-4 ohm load with that sub you need an amp that does 500 + @ 2 ohms |
Silver Member Username: DannyboyyPeterborough, NH USA Post Number: 255 Registered: Jun-06 | what amp u got? |
Bronze Member Username: Tiggerboi87Pensacola, FL United States Post Number: 43 Registered: Jun-06 | the alpine MRD-M605 |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1955 Registered: Oct-05 | * 300 watts x 1 chan. at 4 ohms * 600 watts x 1 chan. at 2 ohms thats amp would work perfect with that 1 sub. wire that DVC 4 ohm sub to 2 ohms and you will be set --- and you said it wouldnt work tigger |
Bronze Member Username: Tiggerboi87Pensacola, FL United States Post Number: 44 Registered: Jun-06 | haha im nwe at this thing and i though if the sub wuz a four ohm sub it had to be wired at 4 ohms and visa versa |
Bronze Member Username: Tiggerboi87Pensacola, FL United States Post Number: 45 Registered: Jun-06 | well ok now what would be a good box for them. I want them to really hit and i have a 88 blazer s-10. I had one rockford p2 12 and i though that hit pretty good and this should hit much louder and harder right? |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1962 Registered: Oct-05 | no, lol. its ok (2)4 ohms sub wire to a 1 or 4 ohm load (1) 4 ohm sub wires to a 2 or 8 ohms load. your tryin to match what the sub wires to, with the amp depending on how much power the amp puts out at that ohm load. for quick wiring: go to www.the12volt.com--- go to the left---- go to woofer wiring --- select one sub --- selet dual 4 ohm in the next box --- then wire to the 2 ohm load |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1963 Registered: Oct-05 | it should, yes. def. port the box. look on their website and see if you can find what the rec. ported box enclosure is |
