Silver Member Username: BobkakabobkakaPost Number: 230 Registered: Jun-06 | Ok..I am really confused...someone who is really kind please be patient and help me out...ok here goes: My dish is not on a plump mast, and my elevation is like below 0 degrees by like 20 degrees. It is currently pointing about 270 degrees (azmith). I am using a single LNB (i.e. one coxial cable cmoing out). Ok...when I enter my pansat 2500a menu and go to installation, then to antenna setup...I get this: T-5/Ku: LNB Type: Standard Freq: 10900 . . Skew: 45 . . . Level 90 Quality 50 Echo 4/Ku: LNB Type: Standard Frequ: 11250 . . Skew: -45 . . . Level 87 Quality 40 Echo 9/T-13/Ku: LNB Type: Standard Frequ: 10750 . . Skew: -45 . . . Level 87 Quality 40 Echo 1.2/Ku: LNB Type: Standard Frequ: 11250 . . Skew: -45 . . . Level 87 Quality 40 Echo 7/Ku: LNB Type: Standard Frequ: 11250 . . Skew: -45 . . . Level 87 Quality 40 Echo 8.10/Ku: LNB Type: Standard Frequ: 11250 . . Skew: -45 . . . Level 87 Quality 40 Nimiq 1/Ku: LNB Type: Standard Frequ: 10900 . . Skew: -45 . . . Level 87 Quality 40 Nimiq 2/Ku: LNB Type: Standard Frequ: 11250 . . Skew: -45 . . . Level 87 Quality 40 Echo 3/Ku: LNB Type: Standard Frequ: 11250 . . Skew: -45 . . . Level 87 Quality 40 When I blind scan every satellite...I get the same channels...which are some int'ls 1 ppv (which is international) and the locals...etc. Which right now only locals are working but thats not my problem at the moment. So how can all this be true with 1 dish, 1 standard LNB, and no dish movement?? Someone please tell me wat is going in... I live in the Greater Toronto Area and I live 35 meters above ground level and my dish is behind a window...a very large window...so ya...help please. BTW all the channels I get are DN...no BEV. |
Silver Member Username: BobkakabobkakaPost Number: 231 Registered: Jun-06 | Man look at this...everyone is wasting their energy answering stupid threads like that HO girl who posts picture and that LK apology thingy...guys this is an FTA disscussion forum not a friggin realty show...seriously someone help me and answer my question bfr my thread moves to the bottom of the page and no one looks at it. | |
New member Username: Jenifer_contrerasTampa, Florida USA Post Number: 2 Registered: Jul-06 | OMAR READ THIS: You can use the 18" dishes and LNBs from Dish Network or DirecTV. Most of these dishes come with DSS (legacy) LNBs. The basic LNB specifications are: type = DSS KU band; input frequency range = 12.2 to 12.75 GHz; output frequency range = .95 to 1.5 GHz; polarization = circular; local oscillator (LO) = 11.250 GHz; it has no builtin switch. If you have any doubt about your dish and/or LNB, there are many references on the web as to what works. The drawback to using standard 18" dishes is that you probably will have to mount a separate dish for each satellite. You can cobble together an 18" dish with multiple LNBs but you will lose some performance -- this can be a big problem in northern U.S. and Canada. In this case, you should consider a larger dish for best performance. 1.3.5.2. Mounting the Dish: When you mount the dish, use a level to get the mount as plumb as possible. Locate a satellite finding program on the web (http://www.satlex.de/en/azel_calcfirst_1.html). Use it to get the elevation and azimuth of the satellites that you want to find in relation to where you live. For this example, lets assume that you want to find 110 (Echo6,8) and 119 (Echo 7), the Dish Network satellites. 1.3.5.3. Preliminary Setup You may want to buy or borrow a "Satellite Finder" tool. They cost between $15 and $400, a $15 one will work just fine. It is a signal strength indicator that has a meter, and often a sounder or buzzer. The more expensive ones identify the actual satellite to which the dish is pointed and do not need to be connected to a receiver to work. The Satellite Finder can greatly ease dish alignment, especially if you cannot see the receiver's onscreen display from the dish. Turn the receiver off. They are sensitive static electricity, so anytime that you disconnect or reconnect an LNB make sure that the receiver is off -- unplug it or shut the power off with the switch on the back. Starting with one of the dishes (satellite 110), mount the dish with the screws loose enough so you can move the dish but not so loose that the dish will not stay where you put it. Connect the dish's LNB directly to the receiver (no DiSEqC). If you are using a Satellite Finder (the inexpensive kind), at the dish connect it to the LNB and to the cable that connects to the receiver. 1.3.5.4. In the Receiver: . Make sure that the cable that goes to the LNB is connected and then turn the receiver on. . Go to the main Menu and select "Installation." . In the Installation Menu, select "Antenna Setup." . In "Antenna Setup" you should only see the satellites for which you previously loaded the channel list (110 and 119). Choose the satellite that you want to set up first (110 here). Enter the following settings -- they apply to satellites Nimiq 1 (91), Echo 6&8 (110), and Echo 7 (119). .* LNB Type = Standard .* LNB Local Freq. = 11250 .* 22KHz = Off .* DiSEqC = Off .* Skew = 0 .* TP = any, in this case .* Positioner Setting = Disable .* Satellite Scan = All . Exit Antenna Setup and Save . Exit all the way out of the Main Menu. The channels will probably say scrambled or bad . Hit the "SAT" key on the remote and select satellite 110. . Only the satellite 110 channels are displayed. Select a channel (this ensures that you are on satellite 110) and Exit. . Hit the "SIG" key on the remote and check the Signal Strength Meter. Signal meters find ANY satellite that is close to the alignment of the dish. What is done by setting up the receiver to view a channel on satellite 110 is that as soon as you find the correct satellite there will be picture and sound on the selected channel -- thus, you are guaranteed to be on the correct satellite. 1.3.5.5. At the Dish: . Adjust the dish to the correct elevation for your state/province. All dishes have degree indicators on them, though not usually very accurate; use them to help you adjust the dish. . Slowly rotate the dish in the general direction of the satellite's azimuth using a compass as a guide. Standing directly under the dish while using the compass is usually the easiest way to find the correct heading. . Use the onscreen satellite Signal Strength meter in the receiver ("SIG" on the remote), or a Satellite Finder tool if the TV is far away. The Satellite Finder will make a sound that gets more intense as the dish comes into alignment with a satellite. The intensity of the Satellite Finder tool can be turned down as the signal gets stronger. This increases the dish's position sensitivity while you are trying to get the dish perfectly aligned. Remember that the Satellite Finder tool will find any satellite that is close to the direction of the dish, so when the sound gets more intense and the meter kicksup check the TV to see if the channel that you selected has picture and sound and is the correct channel. If not, you are not pointed at the correct satellite. . Alternately adjust both the elevation and azimuth in very small increments until the signal is at its maximum. Then tighten all bolts to clamp the dish permanently into position. . Now repeat the process for each additional dish/LNB that you are setting up. . After all dishes/LNBs are setup, shut off the power to the receiver and install the DiSEqC. If you are using only one LNB, you do not need a DiSEqC and can skip the next step. . Now, turn the receiver power back on, go back into "Antenna Setup" and select the correct DiSEqC number for each of the connected LNBs. The numbers on the DiSEqC where the LNBs are connected should match the numbers entered for DiSEqC in the Antenna Setup menu. Save and Exit, Exit all the way out of the menu. 1.3.5.6. Watch TV! |
Silver Member Username: BobkakabobkakaPost Number: 232 Registered: Jun-06 | Jeni, I have this PDF guide but my situation is a bit different... | |
New member Username: Jenifer_contrerasTampa, Florida USA Post Number: 3 Registered: Jul-06 | Sattelite angle calculator
New member Username: Jenifer_contrerasTampa, Florida USA Post Number: 4 Registered: Jul-06 | I sorry OMAR | |
New member Username: Jenifer_contrerasTampa, Florida USA Post Number: 5 Registered: Jul-06 | Ones I got the same, Just receiver vent crazy,I restored to original bin, made blind scan,and then flashed with BIN from BL | |
New member Username: Jenifer_contrerasTampa, Florida USA Post Number: 6 Registered: Jul-06 | But now I got more funny...My Pansat can changed time and date up to 3 time a day...so always problem with epg. | |
New member Username: LatmanPost Number: 1 Registered: Jul-06 | You are the best, Jenifer | |
Silver Member Username: BobkakabobkakaPost Number: 234 Registered: Jun-06 | Jeni, r u the same Jenifer from the LK thread? P.S. This still doesn't solve my problem...someone please help. |
Bronze Member Username: Viet004Post Number: 18 Registered: Jun-06 | ok what channel are you looking for, like most sport espn hbo cinemax, or you like more ppv?. let me know i'll try to show you, even though i'm very new to this stuff. hehehe | |
Silver Member Username: BobkakabobkakaPost Number: 235 Registered: Jun-06 | just want some internationals and i wanna watch soccer... | |
New member Username: Jenifer_contrerasTampa, Florida USA Post Number: 8 Registered: Jul-06 | Yes its Me dear. I try to help you out but racsui vimacsui... |
Bronze Member Username: Viet004Post Number: 19 Registered: Jun-06 | how many dish do you have, one dish only can pick up one signal, except the pro dish. | |
New member Username: Jenifer_contrerasTampa, Florida USA Post Number: 9 Registered: Jul-06 | i wanna watch soccer...what channel is it ? | |
Silver Member Username: BobkakabobkakaPost Number: 236 Registered: Jun-06 | Jeni...y r u calling me "dear"? luong..i have 1 dish |
New member Username: Jenifer_contrerasTampa, Florida USA Post Number: 10 Registered: Jul-06 | Thanks Jorge Pelaez ! | |
Silver Member Username: BobkakabobkakaPost Number: 237 Registered: Jun-06 | Who are you talking to? | |
Bronze Member Username: Viet004Post Number: 20 Registered: Jun-06 | omar san do you have yahoo messenger we can chat up there cause i dont want to mess up the forum my yahoo messenger is my user name |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 11 Registered: Jul-06 | if You dont liked Habibi,ok in america they use dear. dear Omar. |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 12 Registered: Jul-06 | Omar..at list I made you tread up !!! so I am Mapsut now. | |
Silver Member Username: BobkakabobkakaPost Number: 238 Registered: Jun-06 | y would you call me habibi in the first place? | |
Bronze Member Username: DonyahelwaPost Number: 22 Registered: Feb-06 | Omar, get t5/ku and see Tapesh TV. My be Iranian tv! I have seen Setanta Sports coverage on a Asian channel too. Get you sat strait and look for these channels. Tapesh TV has a replay of today's match right now GER & ARG. |
Silver Member Username: BobkakabobkakaPost Number: 239 Registered: Jun-06 | donyahelwa...wats the code name for Tapesh TV?? (i.e. Code name for Alarabia=alara) | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 13 Registered: Jul-06 | Omar dont give to nobody your messenger...and all this shi*t. Very izy to hack you. | |
Silver Member Username: BobkakabobkakaPost Number: 240 Registered: Jun-06 | I no I no...Jeni why do u care about me so much? | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 14 Registered: Jul-06 | I called you habibi in first place. It's was a signal for you "I am Moroccans Princess" be on my side....something like this. | |
Silver Member Username: BobkakabobkakaPost Number: 242 Registered: Jun-06 | Do you like me or something? | |
Bronze Member Username: DonyahelwaPost Number: 23 Registered: Feb-06 | Tapesh TV. That is how I see it right now! I don't know what you mean by "code name"! sorry |
Silver Member Username: BobkakabobkakaPost Number: 243 Registered: Jun-06 | donyahelwa...wat reciever do u have? | |
Bronze Member Username: DonyahelwaPost Number: 24 Registered: Feb-06 | Fortec Ulltra. Man, you're quick! woo | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 15 Registered: Jul-06 | care about me so much? I dont know, realy. I dont want you think about me so bad.Or Ala want like that. | |
Silver Member Username: BobkakabobkakaPost Number: 244 Registered: Jun-06 | wat bin? | |
Bronze Member Username: Viet004Post Number: 22 Registered: Jun-06 | what the hell, just know the messenger and you know how to hack people, wow you are a super genious, please hack me since you add me to you buddy list | |
Bronze Member Username: DonyahelwaPost Number: 25 Registered: Feb-06 | The last one. Which is 277. | |
Silver Member Username: BobkakabobkakaPost Number: 247 Registered: Jun-06 | so ur using a pansat bin? | |
Bronze Member Username: DonyahelwaPost Number: 26 Registered: Feb-06 | yes. | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 16 Registered: Jul-06 | Do you like me or something? I see you in halyal dely, you got out from your black BMW 745...wow I think whata men "prince ABDULA" he have to be my..that is it | |
Silver Member Username: BobkakabobkakaPost Number: 248 Registered: Jun-06 | can u send me the bin please, my email is smartnerd@gm*ail.com remove the * | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 17 Registered: Jul-06 | Omar do you see how pips come to you ! | |
Bronze Member Username: Viet004Post Number: 23 Registered: Jun-06 | omar san you can get it here, |
Silver Member Username: BobkakabobkakaPost Number: 249 Registered: Jun-06 | wat do u mean by "pips" | |
Bronze Member Username: DonyahelwaPost Number: 27 Registered: Feb-06 | I don't have it right now. I'm at work in my break time. But listen t5/Ku don't care what bin you have! it is a True FTA and Tapesh TV is a True FTA. Also the Asian channel. But I think I got if from al7bar*.tk look for the last bin by BL. It should be at the top. Their server is kinda slow. Make sure it is 277T. "T at the end" | |
Bronze Member Username: Viet004Post Number: 24 Registered: Jun-06 | hahahha she must have like you, she care peoples hack to your comp | |
Silver Member Username: BobkakabobkakaPost Number: 250 Registered: Jun-06 | thx donyahelwa...your much better than Jenifer. | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 18 Registered: Jul-06 | pips=pioples Omar. |
Silver Member Username: BobkakabobkakaPost Number: 251 Registered: Jun-06 | Jeni...why did you stop posting...I wanted to talk to you more...your fun. | |
Bronze Member Username: DonyahelwaPost Number: 28 Registered: Feb-06 | thank you 2 Omar. Ask al7bar about soccer. They may have an answer for you. Or may have a thread talks about that already. PS. No body is better than any one. Good luck. |
Silver Member Username: BobkakabobkakaPost Number: 252 Registered: Jun-06 | Jeni you like me dont you? | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 19 Registered: Jul-06 | ok omar...kalmar. this is your shukrie for me.I got you pips over here...and all shukrie go to donyahelwa ..."thx donyahelwa...your much better than Jenifer." SHARMUTA |
New member Username: Baibee666Post Number: 1 Registered: Jul-06 | HOW DO I REPROGRAM MY PANSAT 2700A?? ITS DOWN RIGHT NOW...IM NEW TO THIS OR EMAIL ME AT BAIBEE666@MSN.COM | |
Bronze Member Username: Viet004Post Number: 25 Registered: Jun-06 | omar san u using pansat 2500a original or clone | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 20 Registered: Jul-06 | Jeni you like me dont you? now no | |
Silver Member Username: BobkakabobkakaPost Number: 253 Registered: Jun-06 | I was playing with you Jeni...dont overreact hon. | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 21 Registered: Jul-06 | ok ok just you know | |
Silver Member Username: BobkakabobkakaPost Number: 254 Registered: Jun-06 | send me ur real pic Jeni. luong...I have a real pansat 2500a. |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 22 Registered: Jul-06 | They are real...where my face is close ! | |
Silver Member Username: BobkakabobkakaPost Number: 255 Registered: Jun-06 | Ok...if they are real...post a pic of you holding a piece of paper that says Jenifer Contreras on it. | |
Silver Member Username: BobkakabobkakaPost Number: 256 Registered: Jun-06 | Its ok Jeni BB, I still love u. | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 23 Registered: Jul-06 | Ok tommorow, now is too dark, and I am alone , | |
Silver Member Username: BobkakabobkakaPost Number: 257 Registered: Jun-06 | send me other pics of you then... | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 24 Registered: Jul-06 | Are You living alone? and what are you doing to get some piss of nice life ? | |
Silver Member Username: BobkakabobkakaPost Number: 258 Registered: Jun-06 | Yes, I'm living alone...I plays soccer alot. | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 25 Registered: Jul-06 | Do you still religion or modern ? | |
Silver Member Username: BobkakabobkakaPost Number: 259 Registered: Jun-06 | are u muslim? | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 26 Registered: Jul-06 | Life in Canada very hard isn't! I hear the tax is crazy. | |
Silver Member Username: BobkakabobkakaPost Number: 260 Registered: Jun-06 | yep 15%. | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 28 Registered: Jul-06 | are u muslim? 50 % Yes! | |
Silver Member Username: BobkakabobkakaPost Number: 261 Registered: Jun-06 | do u have a boyfriend baby? | |
New member Username: Nickik1346Post Number: 1 Registered: Jul-06 |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 29 Registered: Jul-06 | my dady from Dubai and mam from Colombia | |
Silver Member Username: BobkakabobkakaPost Number: 262 Registered: Jun-06 | So do you love me too? | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 30 Registered: Jul-06 | do u have a boyfriend baby? no I waiting to get good bakshish | |
Silver Member Username: BobkakabobkakaPost Number: 263 Registered: Jun-06 | come on msn...wats ur msn? | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 31 Registered: Jul-06 | So do you love me too? what do you think...I feel you are good man and more !!! | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 32 Registered: Jul-06 | I got no MSN | |
New member Username: IcaincPost Number: 8 Registered: Jun-06 | isnt this cute she wait to make more money. he is horn*y because he has no por*no and he calls her a ho. Nice you two diaper heads should get married. | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 33 Registered: Jul-06 | What is time by you now ? | |
Silver Member Username: BobkakabobkakaPost Number: 267 Registered: Jun-06 | so how can we talk? | |
Silver Member Username: BobkakabobkakaPost Number: 268 Registered: Jun-06 | its 2 30 | |
New member Username: IcaincPost Number: 9 Registered: Jun-06 | send us a nud*e jen | |
Silver Member Username: BobkakabobkakaPost Number: 269 Registered: Jun-06 | send me some more pics at smartnerd@gma*il.com remove the * icainc: back off... |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 34 Registered: Jul-06 | icainc you are fockin and over fockin G*A*Y, and when you finished to make blowjob go sucka wash you fockin face all over sperm...sucka bitcha | |
New member Username: Baibee666Post Number: 2 Registered: Jul-06 | IM NEW TO THIS. CAN SUM1 TELL ME HOW TO PROGRAM MY PANSAT 2700A? EMAIL ME AT BAIBEE666@MSN.COM | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 35 Registered: Jul-06 | ok OMAR i'll do it tommorow. I am going to sleppy now.Salam, stay cool. Regard Jenifer. |
Silver Member Username: BobkakabobkakaPost Number: 270 Registered: Jun-06 | ok. | |
New member Username: IcaincPost Number: 10 Registered: Jun-06 | Sorry don't speak bag. | |
Bronze Member Username: IcaincPost Number: 11 Registered: Jun-06 | Next time don't use this forum for your personal use. Get a room! | |
New member Username: BilehPost Number: 3 Registered: May-06 | i m new , can som1 help me and tell me how to program pansat 2500 xaji_bileh@hotmail.com any new key tks |
New member Username: Sidi_orlandoPost Number: 1 Registered: Jul-06 | does anyone knows where we can get the new bin for Viewsat or cool*sat? Still have black screen on all channels |
New member Username: BeautyDubai Post Number: 1 Registered: Jul-06 | now that they cant watch po8n they have to start trying to find something here as we can see and start saying they are form countries they never even dreamt to be from this is for jeni ya bnt elkalab ya gahba inti wla imaratiya wla shay ya sharmoota roo7i il7asi zoob el boyfriend that u have and next time dont lie about where u are from ya bnt el 3ashara waragaat looool this is for omer everyone that tells u habibi not neccesarily knows what they are talking about its a 250 pounds lady who has no self esteem and trying to prove she is the one in the pic that she took from a po8n site and claims its her shoof ya omer ya habibi lol hadi wahda kadabaa wla abooha emarati wla shay that is a big joke yala slaam ashofak 3la 7heer la t7ali hadi tel3ab feek haa |
Silver Member Username: BobkakabobkakaPost Number: 274 Registered: Jun-06 | s...walak ba3ref haidi gahbaa...bas can bedy al3ab fehaa...ya zelama ihda...haidi habla wa ghabaa...hahaha... | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 36 Registered: Jul-06 | to S (dubai)...: Kessek ba ayri sharmouta. |
New member Username: Fta420testerPost Number: 5 Registered: Jun-06 | Good one s. "guys this is an FTA disscussion forum not a friggin realty show" -Omar | |
Bronze Member Username: RadamesPonce, Puerto Rico Post Number: 24 Registered: Jun-06 | Jenifer, I have a same problem with my Pansat 3500 sd. For fix the problem check the tp automatic update and if turn on , put in off. The problem is the DN send signal that kill a clock I have a same problem and after put off the tp update the clock of my pasat no have more issus. rada |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 37 Registered: Jul-06 | Thanks a lot Radames! I got it right now. after that I got this |
Silver Member Username: JohnnerMiami, Florida Post Number: 298 Registered: Nov-05 | Better late then never! | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 38 Registered: Jul-06 | Nice soccer playing on T5 |
New member Username: Connie_sKingstonJamaica Post Number: 2 Registered: Jul-06 | is there a satellite name bell 91 and bell 82 i was messing around with my pansat and they came up if so do you have to move the dish to get them | |
Silver Member Username: AbjPost Number: 174 Registered: Feb-06 | yes, bell is the Bell Vu ( another words its bev ) yes you do have to move you dish to you right standing behind the dish |
New member Username: BeautyPost Number: 2 Registered: Jul-06 | loool ya omer look like jenni wanted u so bad that she had to act so good 3angad habla ya jenni u sound lebanese am i right with out any bad language hahaha they like to say that word u used on me w/c i dont really care lmao and omer ok ok ana ra7 ahda el3ab 3la mahlak el3ab lol | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 49 Registered: Jul-06 | S(dubai)...lo lo lo, you are jealous ! ken ? lechtezdaen ! Yala motek lech abaita ! |
Silver Member Username: BobkakabobkakaPost Number: 279 Registered: Jun-06 | Jenifer...you are a retard...you actually think I believed all the crap u crapped out??? Yo it was sooo fun watching you fall into this you DUMAZZ...Im really a 13 year old kid who lives in Edmonton and is Portugese...I got my arabic friend to write and read all this stuff for me...you are a bored HO who is just looking for men...and you are probably lebanese (what a HO lol!!!), I bet you are a MAN!!! Anyway I was half stoned when I wrote all this crap yesturday...yo (s) wasn't that FUN!!! Jenifer...you retard...loooooooooooooooooooooooooool. | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 50 Registered: Jul-06 | So OMAR ,then I fock YOU, your Friend, yours MAMA , PAPA, SISTERs and BROTHERs...all of YOU forgot what is Islam....All of you start eating pork over here...drinking and smoking. Whata fockin shame...but soon .....you will suck big DICK. Fock you ! riped a$$hole...sharmoota, g*a*y. | |
Bronze Member Username: MinPost Number: 62 Registered: Jun-06 | OMAR , I have been reading u and her posting all night last night , finaly u wake up , just think about it , if she so hot what she doing in the weekend sitting at the pc sound like she having get laid for years ...THINK ABOUT IT MAN ... | |
Bronze Member Username: IcaincPost Number: 12 Registered: Jun-06 | HA HA, see I told you he was a kid. Poor LK defeated by a kid. Sad. Hey child, you better behave or I'll call your momme. Omar is a sharmout | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 52 Registered: Jul-06 | mini rocky. dear barby kent.Do you think I need this Omar, no, no need and you now why...coze it's not real men ,he is realy bull shi*t.And that is why he playing a lot of soccer no girlfreind nothing to do else.He does't no how to tread women, he is G*A*Y.with his aravi boyfriend. |
Bronze Member Username: IcaincPost Number: 13 Registered: Jun-06 | You don't need him Jen, in fact find someone not on the internet. | |
Silver Member Username: BobkakabobkakaPost Number: 280 Registered: Jun-06 | You icainc I didn't drive out LK that was Dish Newibe...Jenifer...looks like you forgot about islam...looking for men on the web...thats not wat muslims do...I just wanted to teach you a lesson HO...no go and be a good girl and dont diss someones family just cause yours abandaned yo HAHAHAHAHAHAHA....LK was right...this is a useless forum...maybe I'll join him one day...LMFAO. P.S. "I fock you, ur friends...etc.." how could you do that...I was right, you are a MAN. HO!!!HAHAHAHAHAHAHA |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 53 Registered: Jul-06 | Thanks Icainc. Any way I am not looking yet...coze I am in Army now. | |
Bronze Member Username: IcaincPost Number: 14 Registered: Jun-06 | You talk shi*t about LK, you can see it throughout the threads. | |
Bronze Member Username: IcaincPost Number: 15 Registered: Jun-06 | Good for you, there are plenty of real men in there. Good luck with your career. | |
Silver Member Username: BobkakabobkakaPost Number: 281 Registered: Jun-06 | Muslims don't have girlfriends cause they know its a waste of time and its haram you dildohead... BTW...I am muslim...just cause I'm Portugese...dont go assuming Im not u terd. |
Silver Member Username: BobkakabobkakaPost Number: 282 Registered: Jun-06 | Which thread icainc?? | |
Bronze Member Username: IcaincPost Number: 16 Registered: Jun-06 | Even if she is a ho, your a sharmout. Go play with your friends kiddy | |
Bronze Member Username: IcaincPost Number: 17 Registered: Jun-06 | Here one post. Guys...if it isnt LK why hasnt he responded to this? |
Bronze Member Username: IcaincPost Number: 18 Registered: Jun-06 | Heres another. Posted on Friday, June 30, 2006 - 11:11 pm: -------------------------------------------------------------------------------- LK...you posted again...that means your back!!! |
Silver Member Username: BobkakabobkakaPost Number: 283 Registered: Jun-06 | How is that sh*t, I'm just saying it could be LK, I am not saying anything wrong...plus get a life u moron...I'm smart cause Im 13...I fooled u all....I get help whenever I have a problem and when I don't I screw you all....HAHAHAHAHAHAH...IDIOTS sitting behing a comp allday...MORONS>> | |
Silver Member Username: BobkakabobkakaPost Number: 284 Registered: Jun-06 | Ok icainc...how is saying LK you are back bad??? What kind of moron are you...you TUBE. | |
Bronze Member Username: Flatulant_kittyPost Number: 13 Registered: Jul-06 | Rats jumping sinking ship maybe? No wait see.We see if it not ok tomorrow.LK, All others go away leave only how too things,things be better.Morons figure this out if only read like morons say read but morons like heros gotta think they helping but make all look like morons.Morons. | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 54 Registered: Jul-06 | omar dickhead ,go to play soccer or to suck dick with your friend, you are so sharmoota,an alabook | |
Bronze Member Username: IcaincPost Number: 19 Registered: Jun-06 | There's more butt pirate, look at June 30th and 29th. I'm not gone to play your g*ay boy games. | |
Silver Member Username: BobkakabobkakaPost Number: 285 Registered: Jun-06 | Jenifer I hope you learned your lesson...and don't diss my friend (hey at least I gotta a friend)...and you are really sad considering that you are trying your hardest to diss a 13-year-old. HAHAHAHAHA...expand your vocab yo "purple-dick fu*k monkey" all u use is sharmota...which I learned means something along the lines of a HO...self reflection...HAHAHAHHAHAHA)...this is jokes. | |
Bronze Member Username: IcaincPost Number: 20 Registered: Jun-06 | AcooTiHerrAN Omar your a tashasha. Get lost. | |
Silver Member Username: BobkakabobkakaPost Number: 286 Registered: Jun-06 | All your insults do not affect me...I am smarter than that...ok back to FTA... | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 55 Registered: Jul-06 | Bobkakabobkaka is a group sex practice wherein a series of men take turns ejaculati_ng onto someone. There are strong overtones of er_otic humiliation in this practice. Various styles exist, but a common form of Bobkakabobkaka seen in such publications will involve a woman or man sitting, lying down, or kneeling while men approach to masturba_te until they ejacu_late on her/his body, primarily on the face or in the mouth. The semen is left on the face as another man repeats the routine. HA HA HA...nice name you got, frickin G*A*Y |
Bronze Member Username: IcaincPost Number: 21 Registered: Jun-06 | Jen control yourself, he is not worth the bandwidth. Ladies should not talk that way. You more mature then he is. He is just a 13 year old punk, trying to get your goat. | |
Bronze Member Username: IcaincPost Number: 22 Registered: Jun-06 | Are you O.K.? | |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 57 Registered: Jul-06 | Thanks Sir ICAINC. I am OK | |
Bronze Member Username: IcaincPost Number: 23 Registered: Jun-06 | You seem to be a smart lady, a lot of people enjoy your help here. Don't waste your time with immature people, they only drag you down. If you are looking for a internet friend, you have one here. I'm also sure that you have a lot of other friends from what I have read. Work hard towards your goals in life. | |
Bronze Member Username: Ticat900Post Number: 12 Registered: Feb-06 | omarsan or whatever you dumb muslim POS get the hellll outta here.U make me laugh |
Bronze Member Username: IcaincPost Number: 24 Registered: Jun-06 | gotta go talk with you latter | |
Silver Member Username: BobkakabobkakaPost Number: 287 Registered: Jun-06 | You people are plainly sad...look at what society has come to...I tell you people this world is coming to an end...someone says something and all your dirty brains revert to such a low degree of mentality that it is purely disgusting. This is very sad for me to see that all people talk about is sex. Most of the people living in North America are like this and sometimes it makes me wonder how this society has come to such a low level. As I browse through other threads all people talk about is por*nographic channels...no one talks about anything else. I assume that all these people do is watch these por*nographic channels all day long. This truly puts me in excruciating pain just to think about...you people are disgusting. How about you change your life by reading a book, spending time with the family, or going outside to enjoy sports? Read more about human past and explore into the many wonders of this world that are not so distorted. Seriously, try it people...you will see that you will live a happy live and your life will become easier...God will be pleased with you as well (I am sure that in Christianity, Judaism and all major religions...having relations with people who you are not married to is considered a sin). Please I advice you all that this world is full of many other beauties other than items of such immoral value. I apologize for the swearing that I said in this forum--this is a very bad habit that I want to quit, and you shall see no more swearing from me--I am truly sorry. In addition to all of this you backbite and team-up against people just because they did one wrong thing (i.e. LK when he lost his temper). If you all just try my advice you will see that life is beautiful. Sincerely, Omar San |
New member Username: SrnaderiPost Number: 1 Registered: Jul-06 | Is there anyone out can Heeeeeelp? I have Ariza 700 and I lost my chanels, Did not update Autoroll but for some reason I got them back except ppv. Couple days back I lost most of them when I scaned it seems I have nothing.Is there any FIX for it now PLZ |
Bronze Member Username: Bazuka2020Post Number: 66 Registered: Oct-05 | Wow Allan so there is no TV, its time to do some reading only than you will understand why all channels gone. | |
New member Username: TrimmanflPansat 2700a REAL ONE !, SOUTH EAST USA Post Number: 2 Registered: Jun-06 | BOTH OF THESE PEOPLE ARE THE SAME ! LOOK AT THE POST ! Omar San Silver Member Username: Bobkakabobkaka Post Number: 261 Registered: Jun-06 Posted on Saturday, July 01, 2006 - 02:27 am: -------------------------------------------------------------------------------- do u have a boyfriend baby? jameskaden New member Username: Nickik1346 Post Number: 1 Registered: Jul-06 Posted on Saturday, July 01, 2006 - 02:28 am: -------------------------------------------------------------------------------- Upload super dish.zip (50.6 k) JENIFER CONTRERAS Bronze Member Username: Jenifer_contreras Tampa , Florida USA Post Number: 29 Registered: Jul-06 Posted on Saturday, July 01, 2006 - 02:28 am: -------------------------------------------------------------------------------- my dady from Dubai and mam from Colombia Omar San Silver Member Username: Bobkakabobkaka Post Number: 262 Registered: Jun-06 Posted on Saturday, July 01, 2006 - 02:29 am: -------------------------------------------------------------------------------- So do you love me too? JENIFER CONTRERAS Bronze Member Username: Jenifer_contreras Tampa , Florida USA Post Number: 30 Registered: Jul-06 Posted on Saturday, July 01, 2006 - 02:30 am: -------------------------------------------------------------------------------- do u have a boyfriend baby? no I waiting ! She or he ask the same ! |
Bronze Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 68 Registered: Jul-06 | Leave us alone, stupid jerk, we dont play anymore . | |
Bronze Member Username: SmalltigerPost Number: 23 Registered: Jun-06 | If you have 1 lnb then only one sat you can get.If you have a motorize dish then you can get multi sat.Get the angles for one sat then scan that,it you sacn others you will get signal fron the first and the same chan that the first have. | |
New member Username: BeautyPost Number: 3 Registered: Jul-06 | looooooooool LMAO jenni has no other words in her vocabulary except go fock loooooool that is so funny girl or women u need to come up with better than that and omer turned out to be smarter than u do u actually think anyone is gonna belive what u have to write here hahaha jenni if u are so desperate for guys here go to this site www.fat ladies with no hope in life looking for mate.com u are on the wrong site weeeeeeew maybe that will make sense to u oh and pls pls enroll in a esl class where u can actually learn how to write so we can understand some of the useless words u write loooooool ya gahbaa |
