Captive Works has a fix
Username: Ong_tu
Post Number: 7
This is a step in the right direction Ong Tu
Captive Works coders have a nice temporary work around for the latest ECM. This is for the "Premium" CW only. Below is a C&P of how it works. This is a BETA, and is pretty much for testers only. The server they have setup for key sharing (aka card sharing) should handle the load pretty well. there's not many of those on the market yet. The only drawback I see to this temp solution is security. Remember, IP's are traceable. This is good news and shows progress and determination by manufacturers. Next we'll see a cardless solution. The race is on for that one. "May the best man win"
Cardsharing CW600 P V1.19 07-01-2006
This is a card sharing temp fix to get Dish only back up and running. We are working on a final fix as is all the others. We have not had time to just swing by and chat but we are working on it so bare with us.
1.fix the pix problem in nagra2 channel...
2.add cardshare function...
-do F1 555 enable ecm cardshare..
-how to run cardshare watch current dish channel:
-you need the extra tool to run the cardshare
-connect the receiver to computer with a NULL cable and make sure
computer is -connected to the internet.
-open the tool csc.exe
-goto setting-->option->setup correct com port
-goto setting-->start...
-load the new 1.19 firmware on your Premium box
-then go on receiver do F1 555(make sure patch is enabled F1 000)
-if you have correct setup you will see the ecm come on the tool and cw
-Now only dishnet is setup, bev and new other providers will be setup
soon...
have fun...
PLEASE NOTE THAT THIS IS FOR PREMIUM BOX ONLY AND ITS A BETA VERSION
TO SEE HOW SERVER WILL HANDLE THE USERS. FOR REGULAR CW-600 A NEW
SERVER NEEDS TO BE SETUP. THIS WILL BE A STABLE BACKUP SOLUTION WHEN THE
CHANNELS ARE DOWN. CODERS STILL WORKING ON THE REAL FIX AND ITS LOOKING
GOOD.
Username: Ravipatel8
Post Number: 20
links to download the programs plzz
Username: Ong_tu
Post Number: 8
They wont let me post has---so when useing put h in front of ashhu http://www.ashhu.com/forums/
Username: Test
Post Number: 115
Beware though your IP address are traceable. You need to be hooked to internet the whole time you want to watch nasa,
If your IP is untraceable you are good to go, I myself will wait for fix. have fun testing
Username: Ong_tu
Post Number: 9
Yes I gave it some thought I have a good firewall system and Zone Alarm, but I agree wait for awhile.
Username: Biverland
Post Number: 11
This is not a FIX its a BS...Upload
Username: Ong_tu
Post Number: 10
Another retard---can't speak English so I won't retort to his comment.
Username: Boyce
Post Number: 305
It is a real temp fix, for my understand, their sever was down cause by overload.
Username: Sickofattitude
Post Number: 19
7/02/06--> There is No FTA fix at this time, other than what is posted under this statement. This thread will be updated as fixes are posted.
7/02/06--> Down: CaptiveWorks CW600 Premium (with card sharing only) [The CaptiveWorks CW600 P card sharing fix was meant as a BETA test only not meant for wide release to the public. The servers obviously could not handle the demand. It did work and offers a part-time solution for possible future uses.]
7/01/06--> Working Temp Fix: Triple Dragon (with card sharing only)
6/30/06--> Working Temp Fix: Dreambox (with card sharing only)
Username: Ariza
Post Number: 73
LOL captive works is DOWNNNNNNNNNNN
