Switch questions
Username: Idahospud
I have a DP34 switch. I already have the DN 110, 119, and 148 going into it.
My question is, since it only has three connections from the lnb's can I add a two way (sw21) switch between the lnb and the DP34 to add the BEV satelite? Or do I need to get a DP44 switch?
What are the ports on the dp34 that say additional switches?
Thanks in advance.
Username: Johnner
Miami, Florida
Post Number: 286
I'm not sure... the easiest way is to use a 4x1 DiSEqC Switch
Username: Abj
Post Number: 168
go to dssrookie. com and click on search. Type in dp34 and you should get some help.
text/plainUpload
Dish Network DishPRO DP34 Switch.txt (2.5 k)
Username: Connie_s
KingstonJamaica
is anyone still getting cnn wb and upn because i am still getting them
