Pioneer or premier??
Username: Matt12490
Benicia, California USA
Post Number: 1057
I'm about to buy a new head unit and was wondering if i should get a pioneer deh-6800mp or a pioneer premier deh-p680mp?? they seem almost the same but which one is better?
Username: Sweet_subs
Memphis, Michigan Usa
Post Number: 90
the premier is the best poineer stuff that you can buy
Username: Matt12490
Post Number: 1060
thanks but does anyone know the differences that make it better?
Username: Matt12490
Post Number: 1061
hmm didnt bump
Username: Tjmutlow
Post Number: 2452
different voltage preouts is the biggest and warranty if bought from authorized premier dealer..
Username: Matt12490
Post Number: 1062
are higher preamp voltages better than lower?
Username: Northomaha
Post Number: 136
yea, i think it affects how you set the gains also
Username: Mrsq
California
Post Number: 91
well higher volts just means that when you decide to hook up an amp to it, ur amp will not have hard time pushing the subs and your gain can just stay low, and about the difference between premier and regular, well premier is the best of pioneer because of its top brand name but really there the same premier name just sounds better to most people
Username: Bigsim
Australia
Post Number: 120
The premiers do have a higher pre-out voltage, 4v-6.5v between the p8600mp and the p860mp, or 2v-4v between the p6800mp and the p680mp, for example.
Username: Illuminator
Post Number: 3254
It's worth the price boost for the Premier units, it's usually not more than what, $20-60?
Username: Matt12490
Post Number: 1071
$5 acutually =) i already bought it (the premier)
Username: Rovin
Trinidad & T...
Post Number: 8293
good choice on the Premier ! - sometimes besides the better preout they have 2 or 3 extra features
go on pioneer website & do a side by side comparison of ex a 8600/860 or 9600/960 & u will see 4 urself ....
