Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 461 Registered: Sep-05 | Would that be a very good 12" sub? Also what would a good amp be for this being im putting this in a Civic. |
Gold Member Username: Alex_fNear lexington, Ky Us Post Number: 1099 Registered: Nov-05 | Yes that would be a good sub. What is your budget? And what are you looking for, sq, sql,spl??? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 462 Registered: Sep-05 | http://www.onlinecarstereo.com from here i want to buy somthing at about 450 bucks for 1 12" just one 12" and a really good sub aswell as an amp and some good tweeters. I have about a 900 dollar budget. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 463 Registered: Sep-05 | im looking for good SPL. I dont want nothing thts WAAY over the top. Just 1 12" somthing over 500RMS in terms of powerfull. I also know that RMS doenst always mean how much bass it puts out. Id also look to a Capacitor if neccecary. |
Gold Member Username: Alex_fNear lexington, Ky Us Post Number: 1100 Registered: Nov-05 | the best thing to do is go to a couple audio shops and listen to a bunch of subs, and see what you like. Then get them cheaper online. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 7942 Registered: Jul-05 | Its not worth the money... |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 464 Registered: Sep-05 | Well from that site what would u say is a really good buy?? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 465 Registered: Sep-05 | http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14695 or even http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12151 wow its pricey if i could get some more money would that be a really good buy?? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 466 Registered: Sep-05 | http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12514 somthing more buget friendly. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 7943 Registered: Jul-05 | i would get the 13w6v2...but if not the 12w6v2...is also a great overall sub.... |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 467 Registered: Sep-05 | im looking for Sound Quality and Loud so thats SQL not SPL sorry. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 468 Registered: Sep-05 | What amp for one 13w 1000/1? or is there a better amp for cheaper? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 7944 Registered: Jul-05 | yeah... the 13w6...would be my pick..out of the 4 subs u have stated so far |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 469 Registered: Sep-05 | Alright so what amp would go with that 13w6 |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 470 Registered: Sep-05 | What amp would work best with the 13w6? |
Silver Member Username: KillswitchjdPost Number: 224 Registered: Apr-06 | the jl 1000/1? |
Silver Member Username: Bulldogsm2008Iowa City, Iowa Post Number: 253 Registered: Mar-05 | 500/1 |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 7945 Registered: Jul-05 | nope...to much power Jl 500/1 PG Xenon 600.1 |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 471 Registered: Sep-05 | http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16851 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14759 could i wire that 13W to 2ohms and push 600RMS to it? http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15533 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14333 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=11724 Thats probably what i have to work with teh last one is JL im guessing that would be the best buy? |
Silver Member Username: KillswitchjdPost Number: 226 Registered: Apr-06 | its 1000 watts rms..... |
Silver Member Username: KillswitchjdPost Number: 227 Registered: Apr-06 | oh i thought it was the 13w7 my bad |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 472 Registered: Sep-05 | The difference between the JL and Phx im guessing is a bit omre then the 150 dollars isnt it? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 473 Registered: Sep-05 | What about MA http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14759 ? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 474 Registered: Sep-05 | Okay once i descide on the amp i got 2 infinity reference 6002i speakers put in in da rear there decent now id look for 2 good speakers to put up front or should i just get tweeters instead? Other then that ill worry about a capacitory later. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 475 Registered: Sep-05 | If i do get speakers they will just run of the original wires and the power off my Panasonic 50X4 Watt deck. This is where i may get a bit bugety. |
Silver Member Username: Andysd03Post Number: 250 Registered: Jan-06 | get the type X chanuncy just hates them but they are good subs they are cheaper then the JL and just as good if not better dont listen to chauncy lol hes a alpine hater lol tryin to bug u again chauncy i know u dont mind the R;s but i know u absolutly hate the X's lol |
Gold Member Username: James1115Ct Post Number: 6019 Registered: Dec-04 | the x's will keep up with maybe the jl w3's but thats about it!JL subs are far superior to alpine subs and thats just a fact. |
Silver Member Username: LoudonPost Number: 367 Registered: Jun-04 | andy f u should be banned from talking about subs .. in all honesty ... |
Silver Member Username: Andysd03Post Number: 254 Registered: Jan-06 | ya screw u guys just cause one person hates the X dosnt mean their crappy u all beleive one person chauncy hes the guy with all the power u all believe him cause he says type X is cr*ap prop cause he hasnt heard it in the right install they sound awesome alot better then the W3's the w3s are cr*ap one of jl lower subs all u guys think JL is the best well just cause it says the name JL on it. If u heard my type X it change your guys opionions thats forsure nothin matter with it and u guys act like its a type E so really u guys are dumb |
Silver Member Username: LoudonPost Number: 368 Registered: Jun-04 | hey buddy ... im just saying 99 percent of things u say are ignorant ... fine a type x isnt a terrible sub im sure james... chauncey.. reckless.. will agree with that that . but the fact the u recommend that woofer over the likes of DD Audio and JL? Digitial Designs ... makes quite possibly the best competition woofers ever .. and JL Audio.. all the way down to there bottom of the line driver are all way more then exceptional ... alpine is known for their source units ... defintely not for speakers or amplifiers ... although there Type R and X series are average ... i also dont believe that u think just because chauncey doest like type X's that everyone else is going to jump on his back and ultimately agree wit h him ... i guarntee he is way more knowable then u ever will be ... and anyoperson who has expierience in the car audio field will tell u that they are nothing more then an average woofer .. thats about it ... so if ur gonna try and help someone out be my guest ... but dont downplay a good sub such as a Digital designs or JL driver ... cuz they will ultimately decimate any competition ... |
Gold Member Username: James1115Ct Post Number: 6023 Registered: Dec-04 | well said Mike I couldnt agree more, although I think Chauncey know;s what he is talking about I wouldnt jump on the wagon because he says something isnt good. I have heard many type x's in a vast variety of enclosures and like Mike said they are all nothing more then average. Don't reccomend a sub to someone else when you have nothing else to compare it to. If all you have heard is your AMAZING type X I reccomend that you go out and start listening to some different lines such as JL,Image dynamics,RE,DD,Boston Acoustic,Eclipse,Treo,ect.... you will soon find out that your type X isnt what it was all cracked up to be. |
Silver Member Username: Andysd03Post Number: 256 Registered: Jan-06 | ive never downplayed a DD since when did u get that from lol and i said the type X and W7 are the same i wasnt sayin W7 is cr*ap. I know for a fact DD is way louder then a type X but it dosnt have as good SQ though. |
Gold Member Username: James1115Ct Post Number: 6024 Registered: Dec-04 | What are you talking about? you cant say DD as a whole have no SQ because they absolutely do! The 2500's have excellent SQ and get loud, the 3500's have excellent SQ and the ability to get very loud, this continues all the way up the line's with the 9100, the 9500, and even the 9900 have decent SQ. BEfore you post something rediculious know what you are talking about first! |
Gold Member Username: James1115Ct Post Number: 6025 Registered: Dec-04 | also the type X is in no way comparable to a w7 |
Silver Member Username: Camaro823British Colu... Canada Post Number: 424 Registered: Jun-05 | Andy, any conversation with you in it, involves you going off on other people, you need to relax bud its an internet forum where people come to get OPINIONS you don't have to agree with it |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 987 Registered: Dec-05 | andy, you're talking too much, i understand that type X are nice but, DD is way better. The other thing is that you can't argue about a product if you don't know about their quality or if you haven't heard them. |
