Brickwall Surge protector
Username: Titleist
Post Number: 11
I am considering getting a brickwall surge protector but it does not have any coaxial connections. When Directv installs the coax cable is it grounded? I Just want to make sure if there is any kind of hit that anything my directv rec is connected to would not be destroyed. I actually have 2 coax connection because I also have the bulit in DVR. I hear that if the coax is grounded I should be all set with the Brickwall otherwise I may need to consider Panamax
Username: The_wank_artist
Post Number: 1173
Here is a link to a page on grounding your dish.
Hope that helps.
http://www.sadoun.com/Sat/Installation/Grounding.htm
