Capacitor... how do u know which one?
Username: Caraudio
Toronto, Ontario Canada
Post Number: 480
My lights flicker with mt 1200watt lanzar amp now to make it easier on my alt getting a cap would be a good idea? Also how many Farads should it be?
Username: Highstone
Post Number: 256
NO, its not a good idea to get a capacitor when u really need is a Alternator Upgrade. a capacitor will put more weight on ur stock alternator's shoulders.
A cap is just like a battery. So instead of charging one battery( the battery under the hood)now the alternator will have to charge TWO batteries (Cap and ur battery under the hood)
So to solve the problem Get a High Output Alternator. And do the BIG 3 up grade.
Username: Caraudio
Post Number: 491
Well im dropping teh 1200 watt amp and im going to the JL 500-1 amp.
