Silver Member Username: Pike110Post Number: 107 Registered: Oct-05 | Anybody have any ideas? |
Gold Member Username: BlainewPost Number: 1252 Registered: Nov-05 | get an orion 2500d |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1221 Registered: Feb-06 | nope hifonics colosous xx 2 is your best option |
Gold Member Username: TjmutlowPost Number: 2448 Registered: Sep-05 | what are you trying to push? |
Silver Member Username: Loc_outSanta Ana, Ca Post Number: 445 Registered: Feb-05 | Are you looking at 3000 peak? or 3000 RMS? |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 912 Registered: Dec-05 | loc, WTF "3000w peak" nobody wants that! Optidrive 4000d from lanzar is a nice choice, it puts even more and is only 900$. Colossus is nice but is 2 channel, is 3200w bridged. Other choices would be MA audio 4000d and visonik 4000d, they put 4k at 17 volts, You will need the big 3. |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 913 Registered: Dec-05 | talk to B about the autotek 4000d |
Gold Member Username: BlainewPost Number: 1256 Registered: Nov-05 | you can just get the orion for $450 |
Bronze Member Username: KrazyjUSA Post Number: 83 Registered: Jan-06 | MTX TA92001 |
Bronze Member Username: BionickusbLong Island, NY USA Post Number: 17 Registered: Jun-06 | Hifonics XX Colosseus any good ? |
Silver Member Username: CadillacdbHouston , TX Post Number: 721 Registered: Aug-05 | what the hell is juliob talking about >? no one want a amp that hits its power at 17volts and this guy doesnt want any Lanzar junk and nor does he want some MA Audio or Visonik.. this guy is obviously some one that knows better then to buy some Junk like ur offering him as options i would personally get this amp but im a Fosgate guy myself and some dont like fosgate .. but i will tell you this things birth sheet is around 3500rms and i have two of the t10001BD's in one of my cars and i couldnt be happier with um so the power series in a great series fron fosgate altho alot of there old school stuff was much better http://cgi.ebay.com/ROCKFORD-FOSGATE-POWER-AMP-T30001BD-3000-WATTS-MONO-WOW_W0QQ itemZ320001081037QQihZ011QQcategoryZ64572QQssPageNameZWDVWQQrdZ1QQcmdZViewItem that amp then get atleast a 250amp alternator and do the Big three and and get a Kinetiks Monster battery |
Silver Member Username: CadillacdbHouston , TX Post Number: 722 Registered: Aug-05 | at 1 ohm the birth sheets on the T30001BD is around 3500 through 3670 watts rms (varies from amp to amp but only slightly)so i would go with the T30001BD but if you need somthing that does its power at 2ohms i would try the Kicker Kx2500 its birth sheet is usually near the 2800rms at 2 ohms and it will run you about 840 bucks after shipping on ebay and with the extra money add a little and get a high output alternator http://cgi.ebay.com/NEW-KICKER-KX2500-1-MONO-CHANNEL-AMPLIFIER-AMP-M-BLOCK_W0QQi temZ9743520177QQihZ008QQcategoryZ79829QQssPageNameZWD1VQQrdZ1QQcmdZViewItem |
Gold Member Username: RovinTrinidad & T... Post Number: 8267 Registered: Jul-05 | yep ^^^ i fully agree wit cad db ..... |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 926 Registered: Dec-05 | cadillac DB what's your problem man, i'm just saying amps that costs less than 1000$ bucks, sorry if i offended you but all the amps i stated above puts out more than 3000w. Their quality is not the greatest but they put more than 3k. |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 929 Registered: Dec-05 | the ma audio and the visonik put 3500w rms at 2 ohm with 14.4 volt for only 650$. Is not a bad deal and the lanzar puts 4k+ for 800$ at 14.4v. The rockford you said they're nice amps but for 1000$ you can't get them. |
Silver Member Username: Van_manBoston South, MA Post Number: 696 Registered: Mar-06 | Harrison labs Amp3200.X MMAT D3000.1 EarthQuake PHD5000W PowrBass XA3000D |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 930 Registered: Dec-05 | Go with cadillac DB, for 900$ that rockford is a steal |
Silver Member Username: Pike110Post Number: 108 Registered: Oct-05 | I was down to the rockford t30001bd and the kicker kx2500.1 I used rockford a long time ago and haven't used them since. I haven't heard good things about rockford on here. I was thinking that the t30001bd was perfect, but I didn't want to get this amp if there was something out there that is a better deal. thanks for your suggestions everyone. |
Silver Member Username: Pike110Post Number: 109 Registered: Oct-05 | Also, the rockford t30001bd is on ebay for 899 but it is a refurb. Should I stay away from refurbs? It will save me about 250 bucks going with the refurb. |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 937 Registered: Dec-05 | if the amp has warranty, take it. Refurbs are amps new on the inside and an used case to save money. Besides the rockford i do think that lanzar optidrive 4000d is a good deal for the money. 4k+ at 1 ohm, but is you call |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 896 Registered: Mar-04 | Some of you guys that are usually well informed and well spoken become idiots whenever Lanzar is mentioned. The 4000D is legit. Its internals are virtually identical to the Soundstream 6500D. Most of us are aware of what the Opti 2000D can do -- 1900w + at 1/2 ohm -- here is a pic of it next to the 4000D. |
Silver Member Username: CadillacdbHouston , TX Post Number: 723 Registered: Aug-05 | Lanzar just hasnt earned my confidence and ive never seen any Bench test that would make me change my mind about my stand on lanzar |
Silver Member Username: CadillacdbHouston , TX Post Number: 724 Registered: Aug-05 | Now dont get me wrong,, lanzar is fine if you want some of there lower power amps and your looking for somthing cheap that is and ok amp but when it comes to getting somthing thats in the thousand dollar catagory i would much rather have somthing that has my complete confidence |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 949 Registered: Dec-05 | that's true, but man, 4k for 900$ is a pretty good deal, and is very reliable. |
Bronze Member Username: BionickusbLong Island, NY USA Post Number: 19 Registered: Jun-06 | Soundstream PCA 3500 is new and it is very very reliable and puts out close to what it is listed at... Tbey are still a great company |
