Pansat 3500S
Username: Joblo
Im going crazy, is there a fix for pansat autoroll 3500? I just bought mine and it went down on the 20 June. No more auto-roll. Can someone help?
Also is this the best receiver?
What is the receiver that autoroll doesn't go down so often? You guys amazing. Thanks for the help.
Username: Dishnewb
Post Number: 58
First you have to understand that Autoroll has nothing to do with anyting. There is a new ECM taking place as was the case early this month. You have to wait for a fix and load it to your reciver for your reciver to continue working.
Best Reciver depends on who you ask. That is strictly based on people's own opinions.
Hope this helps you out a little bit. And also don't forget to read as much as possible rather than than posting everything that comes to mind.
