Fortec star com1 problem
Username: Starlight
hi all
I can't seem to communicate via port1 on my fortec receiver; jtag works fine, RS232 cable is fine, and I'm using the correct loader, but can't seem to get any response at all from the receiver; can anyone help? thanks
Username: Drbelloim
MOSCOW, VOLG 13 RUSSSIA
U R USING A NULL MODEM CABLE.... U NEED A STRAIGHT CABLE.
Username: Cybercubi
Post Number: 63
What fortec do you have? If it is the classic NA, you need a NULL MODEM cable, not straight thru!
Username: Starlight
it's an Ultra (don't know if its a clone or not); I had this problem along time ago and it took many tries before I was able to conect and download; I had used a straight cable then; I was measuring the voltages on the RS232 chip and noticed that where I was supposed to get -10V (pin 6), I was getting +5V; my voltage is not doubling and inverted as it should; thanks
Username: Bobkakabobkaka
Post Number: 34
Try both straight-thru and null.
Username: Starlight
I just tried the Null, but same result;
Post Number: 36
Does your reciever work or is it dead?
Username: Starlight
it's working, and I was able to jtag twice with no problems;
Post Number: 42
Try another computer, or maybe your computer port isnt working.
Username: Starlight
is there any place I could find a schematic?
Post Number: 43
What do you mean by a schematic?
Username: Starlight
Post Number: 7
I tried several different PC's, but same result;
Post Number: 45
Try a different cable (i.e. a new one)
Username: Evadelparaiso
Puerto Rico
Post Number: 1269
jtag again.
Post Number: 70
But you should try a different cable because he said that Jtag works
Username: Starlight
Post Number: 8
jtaged onced more and cleaned 3 times, but same result;
