BEV and DN can I have both
Username: Aidyn
Post Number: 7
Can anybody explain how to add BEV.
I have echo 3 on one dish and echo 8.6 on another dish.
Should I install one more LNB?
Is Bin file for DN and BEV is the same or different?
How to swich between of DN and BEV if I want to have both of them.
Please explain with details.
Many thanks
Username: Bobkakabobkaka
Post Number: 190
U need 2 dishes or 1 dish and a Disque motor. NO BINS DEPENED ON RECIEVER TYPE.
Username: Rkanak
Post Number: 44
well you can have bev and DN from the same receiver, but you will need to move one of your dish towards bev angles 91W and/or 82W (nimiq1 & nimiq2) 91 and 82 should be towards east direction i.e you will have to move your dish around 6-8 inches towards east(or towards your echo 3 dish) you can have both 91&82 one one dish with 2 lnb's
Username: Jamalrahim
plz hlp 277t bin on fortec clone cannot find place to enter bev keys , no 09 01 provider in nigravision.thk u
Username: Onlyali
Post Number: 48
@ Rajesh ,
In need to catch BEV, iam using echo 3 right now, i think tht is on 61.5 right, should i move my dish to east means right or left since i don have any device to measure , and as u said 6 8 inches, just curious it wud be right or left can u plz tell thx
Username: The_wank_artist
Post Number: 1150
You can have both BEV and 110 and 119 on one dish, no motor, one DISEqC swithc all on one receiver.
Most bins currently have both providers built into them.
I point mine to 110 off the main arm, strap another lnb to it fo 119 and hang another LNB on the other side to catch BEV.
Depending where you live you can do it on an 18" dish, but the bigger the dish, the easier it is.
Username: Dave7717
Post Number: 7
i need keys for bev please help me
fortecstar LT classic
Username: Bhojkumar
Toronto, Ontario Canada
anybody have new keys for viewsat extreme and fortec life time ultra. please help.
