Update BIN cause LNB fried?
Username: Omgu2
is this possible? after updated the bin the LNB doesn't work anymore.
please help!!!
Username: Ong_tu
Where did you get bin?
Username: Dave_singh
Post Number: 10
COOL$5000 I NEED HELP , HOW LONG WILL IT TAKE TO GET A NEW BIN ,I DONT HAVE ANY TV
Username: Boyce
Post Number: 301
I don't think it can fried LNB, but it can fried the recervier.
Username: Omgu2
updated last week and noticed one bird won't scan anything
Username: Boyce
Post Number: 302
you can wait for the new bin come out and try. Or you can bypass the switch make the cable from the LNB to your recevier without the switch between, and scan it again, if it work, it is the bad switch, 7 dollar fix. If not, I guess you have to wait for the bin before anything you can do.
Username: Boyce
Post Number: 303
