ok i wanna buy a 12" kicker Solo X it peak is 5000 watts i was wandering how 2 hook up 2 amps to 1 sub to power it if it is possible (cuz i seen them do it on p/\mp my ride once ) if any body knows plz explain how in a very detailed way other wise cud someone point me in the direction of a powerfull enough amp?
here r the specs Model S12X Size (IN.) 12 Impedance (OHMS) 1 or 2ohm DVC Max Rec Amplifier Power (WATTS PEAK) 5000 Max Rec Amplifier Power (WATTS RMS) 2500 Sensitivity (dB 1W/1M) 87.7 Frequency Response (HZ) 20-100 Mounting Depth (IN.) 8-9/16 Mounting Cutout, Square (IN.) 11 1/4
what amps, if you use 2ohm use 2 zx 1500.1 per sub, if use 1 ohm then use 2 kx-1200.1 per sub. those need alot of space per sub. For spl. those need a 6 cubic ft box per sub.....
