Mono amp question
Username: Lets_talk_sound
Post Number: 44
Can you run three single voice coil subs on a mono amp ? It'd have to be 1 ohm stable, think it be 1.34 ohms....
thanks
Spencer
Username: Extrmndor3
Chicago, Ill Us
Post Number: 1205
yes if u dont excede the minimun impendece and u wire them property will be all good
Post Number: 45
what amp would you suggest thats one ohm stable and inexpensive to push 3 10" ascendant audio assassians. Needs to be one ohm stable, b/c wired at 1.34 ohms. Last question, it says rec power 200 watts yet rms is 350 i thought rms was the rec power. what should I run to each woffer thanks again
Spencer
thanks
Spencer
specs:
Znom 4 ohms BL 12.3 n/a Cutout diam. 9 3/16
Re 3.5 ohms Sd 326 cm2 Outer diam. 10 1/4
Fs 32 Hz Mms 104 g Mounting depth 5 3/4
Vas 37 L Xmax 15.5 mm Weight 14 pounds
Qms 3.63 Spl 85.8 dB 1W/1M Voice Coil diam. 2 inch aluminum
Qes .485 Rec. Power 200 W Voice coil Single 4 ohm
Qts .428 Rms 350 W Cone Paper pulp
Le 3 mH Price $70.00 Warrranty 3 years
Chicago, Ill Us
Post Number: 1211
hifonics go look sonicelectronix.com and look for a hifonics amp
ok bro if ur hookin 3 assasin ull need a hifonics bxi1206d
heres the link
http://sonicelectronix.com/item_6522.html
if im 100% sure your assasin are like 300 rms but because they are ascendant audio they can handle more so 400 rms to each assasin will be alot better and sound better too
that hifonics amp is 1200 rms at 1 ohm so u will be gettin around 700 so each woofer will have around 230 watts it will be underpowering them
so get the bx16005d
http://sonicelectronix.com/item_6336.html
Post Number: 46
are hifonics amps that over rated. I was under the impression that they put out pretty much what they said. And it will be ran at 1.34 ohm so more towards 1 ohm and less toward 2 ohm. And it says 900 watts at two ohms. So i should get say 1000 watts 333 apice... i could definetly be wrong thou
A little confused
thanks for the help
Spencer
Username: Ctmike
Ct.
Post Number: 907
hifonics puts out something like 70-75% of what they state. i'd either look into a hifonic, kicker 1200.1, or pg xenon.
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1924
just get a kx1200.1 or zx1500.1, the subs ohms ratings are usally off by a little like it says svc 4ohm it really is 3.5 ohms, but then you have to figure in box rise, thats where when the sub is in a box, when its playing certain hz's, its impedance (ohm level) will go up so really the amp will see a higher ohm, so if you can afford it i'd get a zx1500.1 that give each sub about 450-500wrms which would make them pound.
Chicago, Ill Us
Post Number: 1223
the hifonics are overated if u dont have the chargin system and a hifonics balance driver
if u have the chargin system ull get 85%-95% of its power.
kicker for me is a waste of money but they are good underated amps, and weell built but they are expensive and phoenix gold is a must buy amp they are legendary not overated and good quiality i suggest get a bx1600d because its overated ull get around 1450 rms at 1 ohm and it will be better for your assaisn
Username: Teddy21
Ann Arbor, MI USA
Post Number: 132
why dont you get an Amp that will put out the same power @ 1 and 2 OHMS?
http://cgi.ebay.com/ebaymotors/JBL-BP1200-1-mono-amplifier-1200-watts_W0QQcmdZVi ewItemQQcategoryZ38638QQihZ003QQitemZ130001691622QQrdZ1QQsspagenameZWDVW
