Wire and distribution block?
Username: Timothy_314
Post Number: 211
#1 im gettin this amp HIFONICS BXi 2006D
#2 im gonna be runnin new wire and im cunfused :-(
b/c i don't know what i should use like a Distribution block b/c there is alot of kinds like
Distribution Block
Fuse Distribution Block
Ground Distribution System
witch one should get??
im gonna be runnin probably 0 gauge wire to a 2 gauge wire so hopfuly that helps :-D
#3 do you know of a site that i could get cheap good power wire and gound wire?
THANKS!!
Username: Tjmutlow
Post Number: 2453
you can run 0 guage to a reg dist block, non fused(youll have fuse near battery) then 2 guage out to amp and any other stuff your running. and you donot rally need ground block, but it kind of helps when running multiple items. ebay is prob cheapest place.
Post Number: 213
aight thanks man, so i just a distribution block that make a 0 guage into 2
Post Number: 214
do i need 2 gauge wire for the gound or 0?
Username: Jonez788
Marshalltown, Iowa
Post Number: 188
Hey, I'm getting the same amp, so I'm sort of in the same boat as you. I have NOT found any 0 to 2 gauge blocks. You need to settle for getting a 0 gauge in, 0 gauge out.
It's a good practice to take the 2 gauge ground wire from the amp to another block, and the final ground to your chassis should be 0 gauge, but you don't have to, you could just take the 2 gauge straight to the chassis.
It's also good practice to use a fuse anytime you change wire gauges.
Username: Rovin
Trinidad & T...
Post Number: 8265
its rec that ur gorund wire wire be = 2 the same gauge as the power wire
so if power wire is 4g
then ground wire should be 4g too & no longer than 3ft if u r bolting it 2 the car's body ....
Username: Jonez788
Marshalltown, Iowa
Post Number: 189
Oh, and also, for wiring..... www.knukonceptz.com but, I don't think they have 2 gauge, you'll have to ebay that one.
Username: Jonez788
Marshalltown, Iowa
Post Number: 190
Do you think you could tell me what that amp has on it for fuses?
Post Number: 215
http://cgi.ebay.com/Stinger-2-Gang-MIDI-Fused-Distribution-Block_W0QQitemZ180001 928446QQihZ008QQcategoryZ50551QQtcZphotoQQcmdZViewItem
Post Number: 217
ok i think i got this now is this all ill need?
#1 Stinger 2 Gang MIDI Fused Distribution Block
#1 http://cgi.ebay.com/Stinger-2-Gang-MIDI-Fused-Distribution-Block_W0QQitemZ180001 928446QQihZ008QQcategoryZ50551QQtcZphotoQQcmdZViewItem
#2 Sound Quest 150 Amp Gold Plated ANL Fuse (for #1)
#2http://cgi.ebay.com/Sound-Quest-150-Amp-Gold-Plated-ANL-Fuse_W0QQitemZ9738762092 QQihZ008QQcategoryZ50551QQtcZphotoQQcmdZViewItem
#3 Stinger HPM 0 / 4 Gauge Water Resistant ANL Fuseholder
#3 http://cgi.ebay.com/Stinger-HPM-0-4-Gauge-Water-Resistant-ANL-Fuseholder_W0QQite mZ9738762025QQihZ008QQcategoryZ50551QQtcZphotoQQcmdZViewItem
#4 Sound Quest 300 Amp Gold Plated ANL Fuse(for #3)
#4 http://cgi.ebay.com/Sound-Quest-300-Amp-Gold-Plated-ANL-Fuse_W0QQitemZ1800021923 56QQihZ008QQcategoryZ50551QQtcZphotoQQcmdZViewItem
that and 16' of 0 gauge wire and 12' or 2 gauge wire (or does that seem to much?)
Post Number: 218
i cant find 2 gauge wire :'(
Post Number: 219
would it be ok if i just ran 4 gauge out of the d. block insted of 2?
