Alright, this has to be good (MTX)
Username: Skythefly13
Ok, I am considering getting this setup:
MTX TC4002 (2 CHANNEL AMP) 1200 WATT
and
PAIR OF 1200 WATT MTX SLEDGEHAMMERS
What do you guys think???
Thanks
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 979
sledgehammer whut......the sledghammer name is jut the name of the box.......n that amp is not 1200 watts more like 400.........
whut do u want in a system n whuts ur budget
My bad,
I'm looking for something MTX thats pretty powerful (just subs right now). I want to get an amp (2 channel) and a pair of 12's. Whats gonna be the best pair? I'm not under a budget right now, just looking for some hard hitting bass.
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1198
^^^^^^^^^^^^^^^^^do not say ur under a budget ppl will start throwin subs tht cost 1000 dollars....so give us sumthing u dont want to go over...
Max 500-550.
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1913
does it have to be mtx, cause you can get a lot better for your money. if it was me it get a kx1200.1 and 2 AA arsenals, but if it has to be mtx get some 7500's and a 1501d amp.
Alright I was just told MTX was pretty good,
I am looking for the combo (any brand) that will hit hard for around 500-550 bucks, what do you guys suggest?
I looked into the KX1200 and its almost 500 dollars by itself :-(
Username: Rick_ross
Post Number: 204
2 cvr's and a zx750.1 will hit hard as sh*t the amp is 300 on ebay and the subs are 160 for a pair on ebay.
Username: Cenus
Post Number: 1915
the kx1200.1 is around $300 on ebay http://cgi.ebay.com/KICKER-KX1200-1-AMPLIFIER-1200-WATT-MONO-SUB-AMP_W0QQitemZ19 0002342684QQihZ009QQcategoryZ79829QQssPageNameZWDVWQQrdZ1QQcmdZViewItem and the arsenals are still on sale as far as i know.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 879
don't think MTX is the greatest, their amps and models from 7500 and up are ok, but they're expensive for the watts they put. Go with dustin's setup, is really nice
Post Number: 9
Wait so I checked out the ZX750.1 and the 2 CVR's and those look real good, but is the amp gonna be able to really pump out alot of bass through both subs? I'm new to this obviously, so hows the mono amp gonna hit through both the subs?
Post Number: 10
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D9744752676&ssPageName=MER C_VI_RSCC_Pr4_PcY_BIN_Stores_IT
Wouldn't I need that for two CVR's???
Post Number: 11
Wouldn't I need that if I had two CVR's???
Username: Juliob
Post Number: 896
the amp is going to push those subs nicely. The amp is underrated. 800w/2 subs= 400w each. That's the reason sky.
