New member Username: Navy_seabees
Post Number: 1 Registered: Jun-06
Posted on Is it possible to receive nimiq one and nimiq two using a dish 500 antenna with two separate lnbs and what would be the sckew . thanks. |
Post Number: 2 Registered: Jun-06
Posted on still waiting on your answer |
Gold Member Username: The_wank_artist
Post Number: 1164 Registered: Feb-06
Posted on You should be able to with two seperate LNBs. You need 9 degrees of seperation between the two LNBs. |
Post Number: 3 Registered: Jun-06
Posted on thanks young man |
