Neon light
Username: Bulldogsm2008
Iowa City, Iowa
Post Number: 220
i know its the wrong section but no one goes to the accesories section very often
https://www.ecoustics.com/electronics/forum/car-audio/241501.html
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2688
im pretty sure it will work...cause its a 12 vdc source wire...and it will ground to the same place
Iowa City, Iowa
Post Number: 226
any other ideas
Username: Mrbockbagok
Edmonton, Alberta Canada
Post Number: 26
Yes it can be done. Cut the cigaret adapter off and cut the plastic wire cover off so you got some wire showing. There should be one wire that has a colored stripe along it. Thats your ground wire. Run your wires to the front of your car, and find a good ground for the one, underneith the steering wheel is where I found mine. Hook the positive wire up to the fuse box and your done. Sorry for bad spelling and gramar
Username: Luisdelbronx
Post Number: 14
I had a neon light hooked up to my subs and i connected power from the radio wire harness - orange wire, then grounded it.everytime i turned the driving lights on the neons would go on, pretty cool.
