Username: Curious Post Number: 70 Registered: Dec-05
Friday, June 23, 2006 - 17:27 GMT Hey guys need some quick help will two kenwood subwoofer amps blow my two twelve inch alpine type r's ive heard of people throwing some crazy stuff on these thats why i bout them but im a little tired of the one amp set up and the amp is rated at 850 watts rms to one channel and i have a two ohm load thanks
Username: Snopro4ever Post Number: 72 Registered: Apr-06
Friday, June 23, 2006 - 17:34 GMT well they only are designed to handle 500, i wouldnt put anythign over 700rms to them, unless you have heard diff. i know they can handle more then they are rated 4, but 850 is 350 over, that is quite a substantil ammount.
Username: Curious Post Number: 71 Registered: Dec-05
Friday, June 23, 2006 - 20:20 GMT ok thats what i was thinking to is there any way for me to get more power to the subs using that one amp you no have them hit a little harder.
Username: Juliob Santo DomingoDominican Re...
Post Number: 811 Registered: Dec-05
Friday, June 23, 2006 - 20:55 GMT 600w is enough for a type R. You can use Dynamat in your trunk, so you'll fell loudness and is the same setup
Username: Curious Post Number: 72 Registered: Dec-05
Saturday, June 24, 2006 - 01:25 GMT I only have 425 going to each sub and i do have my trunk dynamated thanks though
Username: Extrmndor3 Chicago,
Ill
Us
Post Number: 1124 Registered: Feb-06
Saturday, June 24, 2006 - 01:39 GMT dude my cousin is trowin 1.5k rms to a single 15 inch type r and it bumps horrible sq but it bumps with aported enclousure tuned at 43 i think
Post Number: 824 Registered: Dec-05
Saturday, June 24, 2006 - 16:03 GMT jaja of course it has horrible sq, tune it to 30-32 and you'll see the difference
Username: Andysd03 Post Number: 208 Registered: Jan-06
Saturday, June 24, 2006 - 18:27 GMT i bet hes getin some major SPL though!
Username: Curious Post Number: 74 Registered: Dec-05
Monday, June 26, 2006 - 17:06 GMT my box is sealed and i built it my self really not tryn to get anther box
