SETH LOWE
Username: Tweeker
Post Number: 274
do you know what these are the ones pictured on the amp circled 4 of those fell off of my amp when i took the cover off, even though those were off my amp stiil worked. thanks
Username: Tweeker
Post Number: 275
http://img58.imageshack.us/my.php?image=inreside28hc.jpg
Username: B101
Queen City, NC USA
Post Number: 3410
those are capacitors... capacitors store voltage for a short period of time...
Username: Fandim
Reno, Nevada United State...
Post Number: 1228
it's like a very mini cap. It shouldnt hurt anything DRASTICALLY if they're not connected.. But you might want to make sure you have a real capacitor a very short distance from that amp just to help with spikes in current demand, since it no longer even has the smalla mount of caps an amp normally comes with..
Hey B, you hear about RF's 10,000 watt amp that's supposedly only going to demand like 150 amps of current or some such?
Username: B101
Queen City, NC USA
Post Number: 3417
yea Seth Ive seen those. They use a newer type of technology capacitor... they hold the charge way longer than the caps in use now.. its breaking technology actually....
pretty soon, all type of electronics will use these
"super caps"
Username: Fandim
Post Number: 1240
I hope it's all it's cracked up to be.
