Audiobahn a8002v (800rms @ 4ohms)
Username: Caraudio
Toronto, Ontario Canada
Post Number: 421
Good ampp?? Thoughts it would be if i got it to go with the CVX12-2 2ohm DVc 750RMS sub.
Username: Dub_c
Post Number: 97
Same thing as a8002t, but newer looking.
Username: Caraudio
Post Number: 422
When you say same thing is that good or bad?
Username: Dustin3
Tigard, Or U.S.
Post Number: 1785
its a solid amp
Username: Dub_c
Post Number: 98
^^^^ what he said
Username: Fandim
Reno, Nevada United State...
Post Number: 1214
I've had problems in the past with one of the earlier models going into protection fairly easily due to heat.. But other than that, it was a pretty good amp overall. :-) And for the price, it's really difficult to beat.
Username: Caraudio
Post Number: 428
Even with the cool air system it has still went into protection?
Username: Killswitchjd
Post Number: 158
mines gone into protection a few times...
Username: Fandim
Post Number: 1215
Yes, CarAudio. Even with the fan 100% operational.
Username: Caraudio
Post Number: 429
This same model? Maybe thoes lil problems fixed in the newwer models?
Username: Snopro4ever
Post Number: 71
usually the intake series are known for operating well in warmer conditions, due to their large cooling system. i believe it will be a great choice, i will most liekly be purchasing an audiobahn a8000t off ebay... it seems a great choice for the price. i will be powering 2 infinity kappa perfect 12.1 at 2 ohms. they are 350w rms each, but i think they will be fine with 400 rms to each.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1788
mines never overheated or gone into protection :-)
Username: Fandim
Post Number: 1216
Meh... good rule of thumb with car audio is you get what you pay for. :-)
Username: Caraudio
Post Number: 436
How do you know when your spending for quality and not stupidly? When you have a set amount you only have to spend you can make the best of that can you not rather then looking at somthing you cant afford?
Username: Dustin3
Tigard, Or U.S.
Post Number: 1789
well, when you have a set amount (and its not alot) you cant really go for quality. The intake series IMO are very good QUALITY for the money that you do pay for them. then there is quality like MM, jl,.... the list goes on. if you cant afford it, u need to find the best amp that you can afford.
Username: Caraudio
Post Number: 439
Also would the CVX be quality???
Username: Dustin3
Tigard, Or U.S.
Post Number: 1791
yes. its a very nice sub
Username: Juliob
Santo DomingoDominican Re...
Post Number: 815
rules of car audio.
1-you get what you pay for
2-Do it right the first time
3- go to ecoustic.com and ask for reviews on brands jeje lol!
Username: Caraudio
Post Number: 448
You get what you paid for (check ... quality)
Do it right the first time(check (this is the first time i researched b4 i bought))
Here and asked questions and opinions (check)
Now to sell my old system and im so proud my self i rewired the RCA POWER and GROUND to ym CIvic and all the pannels went back in and nothing broke and it works fine and sounds better theres less distrortion where ever it was but the "REM" wire i lef the same as it was b4.
Username: Caraudio
Post Number: 451
Bassman3... if i could spend the extra money to buy from www.edesign.com the elemental desgin 13Kv.2 450RMS and the nine.2x 400RMS would that be a much better buy then the Audiobhan and the CVX which are rated at 800RMS and 750RMS?? What will have a greater output?
Username: Tjmutlow
Post Number: 2424
are you using 2 subs, if so, and they are dula 2 ohm subs, I would use like the zx-1500.1 or the 2500.1, if only using 1 dual 2, i would use a memphis 1000d on it.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1805
why would u want the 2500.1 ty? 2500 is wayy to much for two 750 rms subs. the zx 1500.1 would be a nice choice.
car audio,
the cvx is rated at 750 rms i beleive. so NO ED amps would fit well if you had the two cvx's. Their highest amp only puts out 1200 @ 1 ohm i believe.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1809
and the 13kv.2 is 350 rms not 450. i dont really like the ED subs that much. there alright but i would def stick to the cvx's which IMO will get a ton louder and still keep great sq.
if u could get the 2 cvx's (dual 2 ohm) - and a zx1500.1, you'll be set for a very nice system. better than if u got the ED subs and amp
Username: Caraudio
Post Number: 456
Wow when your being told two ends of the deal both leaning way to their own side its hard to go one way.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1841
ok. do you already have the sub? b/c its all bout' voice coil config.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1842
ur gettin 1 sub correct?
Username: Dustin3
Tigard, Or U.S.
Post Number: 1847
see, i thought u got 2 cvx's?...
Username: Dustin3
Tigard, Or U.S.
Post Number: 1848
just get the a8002v amp :-) good amp, low price and it will power ur cvx nicely
Username: Dustin3
Tigard, Or U.S.
Post Number: 1849
lol
Username: Caraudio
Post Number: 457
i want to get 1 loud 12" of quality. So if i was to choose ED 13Ov.2 or Kicker CVX you would say go kicker?
Im looking to get 1 12".
Username: Racer501
ND USA
Post Number: 378
just to let ya know u can get 2 Kicker 12" CVX's dual 2 or 4 ohm wich ever u want for $360 shipped idk if the guy still has any but thats how much i payed for mine... im working on the box #'s right now so when i start workin on it im gona try n get pics of it but ya look for "Kicker CVX" in ur search thing and you should come up with some
Username: Dustin3
Tigard, Or U.S.
Post Number: 1909
yes. i would say the cvx
Username: Juliob
Post Number: 867
kicker is better than ED.
