26's
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 98
does anyone know in here if 26 inch rims can fit on a 2004 gmc sierra 2x2 sportside truck?????????
Username: Dustin3
Tigard, Or U.S.
Post Number: 1677
lol. that g@y. talk about a bad driving experience
Username: J_baby15
Kentucky
Post Number: 380
maybe if your tires were like paper thin. Look at the biggest possible tire size for you vehicle. Then see if you can get 22s for that size. Like mine is 255s, and they make 255s for 22s, but its really thin, so i would jus go wit 20s. Big rims look good, but theres no need to mess the ride up jus tryin to shine.
Username: Panocha
Post Number: 209
imo i think 24's would be a beter choice
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 327
go with 16x8's and put 33" tires on them haha. i think 26 would be too big. maybe 24's
Username: Lexus_coop
Post Number: 12
26's are the shiznit
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 2314
on the truck , 24's look clean as hell theres one in my town bright blue with 24's its nice
Post Number: 99
the truck is regular cab sportside so if i went with 24's they would look huge but i dont know if 26's would fit or not
Username: Lexuscoop
Pheonix, Arizona USA
Post Number: 932
no they wouldn't fit, if they did, it would look like cr@p, 26's are g@y as heII i agree with andrew, put some 61x8's 33 inch tires, and use that truck for what its ment fo OFF ROADING!!!
Username: Troy81
Tavernier, Fl Us
Post Number: 368
id raise it up and get 26's and put 44 inch mickey thompson mudders on it
Username: Demon_pride
Crowder, Oklahoma USA
Post Number: 178
Rofl @ TS. My 22's look about perfect on my Tahoe. I don't really care for the super-oversized rim look. I just like a nice, clean, chrome.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7879
had 24's went back down to 22's and the ride is much much better
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 960
22's min on any big truck.......
most people dont do this.....when they get rims......the reason the ride is rough is cuz u dont have any sidewall....
my car rides better with rims then it did b4 no lie
rear 275/40/20
front 245/40/18
40 sereis tires......any bigger it would have been an suv tire
they make thiker sidewalls for 22's not sure on 24's ill check for sume
Post Number: 100
killerzracing yea if u would check about the thicker sidewalls for the 24's juss get back to me on that thanks
Post Number: 961
kuhumo stx kl-12
jegs product # 613-6491 (so u can call jegs an ask if u want....nor fone # but product)
305/45/22 219.99 each
5" sidewall so i think the ride will be good....but ur truck will set a little higher than if u had like a 40 or 35 series sidewall but not much prolly
the first number on the tire is width in MM
second is aspect ratio how thick the sidewall is compared to the width so it 45% of 305mm
last rim size just FYI
32.6 tall
Post Number: 109
thanks man can u see about 24's or 23's?
Username: Icecreamman5687
26's i dont think would fit unles u put a small lift for them...ive only seen one car wit them on and that was a caddi escelade ext. those things were freaken huge..and the sad part is a 16yo chick was driving it..dam rich sctosdale people....
Username: Cogdillb
Spearman, TX United State...
Post Number: 13
There is a Tahoe with 26's in my town and they fit but during sharp turns the tires rub the fender well.
Username: Pelona
Perris, California USA
Post Number: 1600
ya 26s will fit for sure but idk if theyll rub or not. it depends on the tire thickness n width
Username: Jeffless600
Post Number: 166
No they wouldnt fit, the 2+2 is lower then the 4+4 and u would have troubly getting anything more then low pro 24"s on it.
Username: Loc_out
Santa Ana, Ca
Post Number: 429
Down here in southern Cali truck have 26 and they look good. Truck or suv that have 22 are just lame. Down here are some huge azz car club from low riders ect. You guys have seen that video from master P i need dub all the cars where from southern Cali.
Username: Justblaze
St.Louis, MO USA
Post Number: 9
i think a 23 would fill out your wheel well nicely.
