New member Username: RogskPost Number: 1 Registered: Jun-06 | Hi, Does anyone know the code to access the service menu for a Samsung 28" TV CW683CNG. I have already tried; PWR OFF - MUTE - 1 - 8 - 2 - PWR ON PWR OFF - SLEEP - P.STD - MUTE - PWR ON PWR OFF - P.STD - MENU - SLEEP - PWR ON when i playback DVD's or freeview via RGB input the screen goes off to the left by about 3-5cm. Also when i play NTSC dvd's i sometimes get a lot of colour bleeding problems where a strong light source in a dark picture streaks across the screen. Event Horizon S. E. was particularly bad for this. Not sure if the service menu will help with the second issue but i believe i can adjust the tint setting for NTSC playback. Any help would be greatly appreciated. |
New member Username: RogskPost Number: 2 Registered: Jun-06 | Hi Just to let you know that i have located the code; PWR OFF - DISPLAY - MENU - MUTE - PWR ON Use the following link to find the service manual for a very similar model; http://www.eserviceinfo.com/downloadsm/6777/Samsung_CW683CW.html Hope someone finds this of use. |
