What Wires Are These?
Username: Blazerboy
Post Number: 11
Hey guys,
I bought a 97' Blazer a couple months back and I was thinking about putting a system in. The previous owner let some wires in the back and they look like they could posibly still work so i'de thought run some stuff by you guys and see if you could help me out...
The first couple of wires are red and black. They are pretty thick. On the wire it says, Rockford Fosgate RP1020R 4 AWG Punch. The red cable has arrows going out of the car, and the black cable has arrows going into the car. Thats about all teh info I know on those, so if you could identify what this is it would be great.
The secound wire is a yellow wire that says Rockford Fosgate interconnect. It also has two plug ins branching off of it. Becides that, thats about all i know about them.
So yea any information on these wires would be appriciated.
Thanks,
Kyle
Username: Astrosafari
Delhi, Ontario Canada
Post Number: 427
depends how they had things hooked up, no one does it the same. those could be wires for any thing, speaker, ground, and pos. who knows, you have to find the other ends
Username: Blazerboy
Post Number: 15
Anyone have any ideas?
Username: Lordvicadin
Post Number: 17
well if it was done right the red is power . the black is ground and the yellow is the remot turn on for the amp. or rca. but still see id they are ran right
Username: Blazerboy
Post Number: 16
Bump, any more ideas?
Username: Rick_ross
Post Number: 143
red is power black is ground and the yellow are the rca's probly. Check your battery to see if the power wire is still connected to it
Username: Rick_ross
Post Number: 144
and look to see if the black wire is grounded to a metal part of your car
