ok ok, I have a 5.1 surround sound Pioneer Receiver. will it work with 4 JBL speakers and 1 Infinity Sub? can all these brands be Compatible? if not, what should I change, because I didn't get the sub yet.
Yes it will work but it sounds like you may go without a center channel. There may be an option for no center on the reciever. If there is, and you are not going to have a center channel use the feature to output the sound to the other front speakers.
